| View Poll Results: Does your Pilot Sputter or Die When Starting? | |||
| Yes, it does it regularly |
4 | 26.67% |
| Yes, but has only happened a few times |
11 | 73.33% |
| Voters: 15. You may not vote on this poll | |||
I have heard most of the issues with the '12, but also with the '11 so I posted it here.
I have owned an '09 and an '11 and have never had the issue a single time. The 2012 does it at least once a day, sometimes more. Please post if the dealer has provided a solution to the problem. Thanks. |
It should also be noted that on SOME '12 Pilots, this issue can be alleviated by pausing in the "On" position (and allowing fuel pressure to increase) before cranking it. Before I began doing this=>2-3 times /week.... After=>zero.
2012 Pilot Touring 4WD RES -- Polished Metal Metallic, black interior. OEM options: chrome side steps, air deflector, roof rack cross bars Previous Pilots: 2003 EX 2WD, 2005 EX-L 4WD RES, 2007 EX-L 4WD NAV, 2010 Touring 4WD RES |
This does indicate a fuel issue. Either they changed the fuel delivery system or the tune. My guess is there will be an updated tune to fix the problems. |
This IS relevant to anyone new to this forum and comes across this poll, assuming that there isn't a workaround until Honda resolves the issue. |
It would appear that we both missed each other's point.
I have 2012 LX with res , Has done it 8 times now and ive only driven about 20 times, Just sat at dealer for 3 days and they couldnt get it to do it, I brought it home and it did it that night. I am asking for another vehicle soon.
Mine has done it a couple of times...it's a '10. It only does it when the key isn't held in the start position for a long enough period. Maybe that's what's going on with all of these. There seems to be a certain way to start the car, and if you don't do it just right, you get the sputters.
2010 Honda Pilot EX 4wd -in Dark Cherry Pearl 2002 Chevzuki Tracker 2-door -w/ 5.5 inch lift and 30" tires 1999 Chevy S10 ZR-2 -Extended Cab in Victory Red |
It would be rather important to see the pilots that haven't seen this "problem" against those that have. This way, for all you know, every pilot could have the problem, but only 5 people chose to do the poll.
Also, there's a multi-page thread up on this "problem."
2011 Honda Pilot EX-4WD. [bought] 2011 Honda Accord Crosstour EXL-4WD. [leased] 2009 Ford Focus SE. [bought] |
#13 (permalink) | |
Yes I know about the other thread, I have posted in it. I can see how a Pilot owner who has not experienced this would not think its a big deal. The reality is the the car should not do this. I had a Chevy Uplander that did the same thing and it was fixed by replacing a bad FPR. The biggest concern I have with the Honda issue is they are turning customers away because they cannot diagnose or fix the problem. This worries me. If I did not own 2 other identical vehicles previously that NEVER did this, I would probably would not think twice about it. |
I had a 11 and it did it in the beginning and then stopped. My 12 has done it a few times but only had this one for a week. I will post again in a week or so but hoping it stops just like the other one did. Not a huge deal as long as the car does start!
