PS in advance: I went to change the title spelling but it wouldn't allow me. Mea culpa. Onward below.
Hi. I just got the codes 123 on my Honda pilot. One of them is for changing the dust and air filters. The other is for rotating the tires. In the last is for transmission fluid. Question: are changing the air filters a big Job? Is it something I can do? I am fairly handy and I'm wondering how difficult it is to access panels and what not to change the filters. I would prefer to change the air filters myself and not a huge charge to the dealer if I can. But for rotating tires I'll let someone else do that. Also is changing the transmission fluid a huge deal? I already know that changing the rear differential fluid is a job a bit too big for me but isn't the same for the ATF? Also if I do decide to do these jobs myself, what would you guys consider reasonable charges if I have to take it to the dealer? |
How many miles when the codes appeared ( just out of curiosity)?
31961 to be exact. Got them with the...oil change. But I was pressed for time and got the oil changed this Sunday, want to do the
tire rotation tranny fluid and air filters myself if I can in December. |
Search forum for DYI tranny and VTM fluid changes ....may helpful hints both are not difficult if you plan ahead with the right tools.
2011 Honda Pilot EX-L w/Navi - Polished Metal Metallic 2008 Honda Civic EX - Galaxy Gray Metallic |
With regard to the ATF replacement, what Honda considers a replacement is really a half-assed replacement (actually even less). When the drain bolt is removed, only 3.6 quarts drain out. Capacity is 8.6 quarts. Most owners of 2nd gen Acura CL/TL change the fluid ourselves and do a 3-by-3 (or even 4-by-3) due to the fragile nature of our transmissions and the constant need for fresh fluid. The procedure is: drain the fluid, refill with same amount as drained, drive around enough for all gears to engage including reverse and then repeat the process two or three more times making 3 or 4 total drain/refill cycles. This will replace most (but not all) of the old fluid. Whether or not this is necessary for the Pilot transmission is debatable as the transmissions have proven themselves to be fairly reliable. Just thought I'd share this tidbit anyway.
________________________________________ 2011 Honda Pilot EX-L 4WD Dark Cherry/Ebony 2003 Acura 3.2 CL Type S Satin Silver/Ebony |
