So -- for the edification of the net and Pilot owners -- I post the following:
My 09 Pilot Touring with 79K on the clock was really vibrating when slowing from highway speeds. It got to the point that the whole car was shaking like a leaf at any application of the brakes at speed. Added to that my dealership service told me about 20K ago that my brakes were "worn out" and needed to be replaced. So I bought the parts and waited for that tell tale metal on metal scraping sound. The only problems is it never happened. No scraping or anything because when I pulled the pads and rotors -- they still has 3mm of life in the rear and 5 mm of life in the front. So much for my dealer being honest. The truth is they were vibrating but it is not clear if stock rotors were warped or whether it was due to pad material buildup. I can't recut the front rotors as I had a difficult time getting them off and kind of "damaged" them in the process. Long story short the fronts were not as smooth as I hoped; but the rears came off like a charm. First of all -- I did not take pics of this process like I should have. For that I apologize. If you go to youtube you can find a good vid on this with a Gen 1 Pilot that covers the process quite well. You will need an impact screwdriver to loosen the 2 low quality and soft phillip head screws that hold the rotors in place. After removing the caliper slide bolts, phillips head screws and caliper bracket -- the front rotors do not simply slide off. At least mine did not. A BFH loosened them but did not allow them to slide all the way off. I needed to thread bolts into the threaded holes and essentially push them off. After that the process was quite straightforward for the fronts. The rears, on the other hand, slid off quite easily. Don't forget to take the rubber grommet for the parking brake adjustment hole and put it in the new rotors. FWIW I used aftermarket rotors from rock auto and they had almost identical markings/measurments as the stockers. Don't see the need to pay 2-3X as much as Honda parts. I mic'd them out and measured runout and all specs were very close to identical between stock and afermarket. YMMV. Hindsight being 20/20 I would have not used the BFH to get the front rotors off and would have had them cut (there was plenty of meat left on the rotors) and thrown new pads in there. Also -- I got the ceramic beck-arnley pads and can say that after 1000 miles they feel exactly the same as the stock pads. Hope this helps. -Dan C.
2009 Honda Pilot Touring w/Nav/Res 1991 Volvo 940se 15G 23 PSI "Slepa Brick" 1986 Porsche 944 N/A |
Thanks for the write-up, Dan! Good info when my time for a brake job comes around...
'11 Pilot EX-L 4x4 Taffeta White (Xenon Depot HID conversion, LED interior lights, Yakima Rack) ![]() '98 Shadow Aero 1100 (pipes, bags, LEDs, etc.) -- RIP -- '08 Element SC 5-Speed Rootbeer Metalic '92 Accord EX 5-Speed |
#3 (permalink) | |
regarding replacing vs recutting... I too was going to go the recut route as the rotors seemed to have plenty of meat left.... but after calling 3-4 shops they wanted $25/rotor to recut - whereas new nonslotted/dimpled were only $10-20 more. I decided to replace to prolong "time til next rotor change"... what are other folks here doing? Sent from my Autoguide iPhone app |
I haven't cut rotors in a long time. The cost difference between cutting rotors and the cheapies I've bought for old cars isn't worth the time and energy. Factory rotors for the Pilot, however, are $112 each. So, I'll probably turn them once.
Current Vehicles: '11 Pilot LX 4wd; '10 Subaru Outback 3.6R; '02 Honda Shadow 750; Pilot v. Outback: http://ohmahdeehness.wordpress.com/2...-two-vehicles/ |
yikes. if I was paying $112/ea for factory rotors I would def cut/turn them once... but by default I presumed that aftermarket was better/equal to factory - for less money.
Agreed, but I'm going factory for my "new" vehicles. Over time I think it will pay off. I used to work parts and there are indeed a lot of good aftermarket parts for better prices. I'm just going to stay factory for the Pilot.
What do you guys mean by "cutting" the rotors? Do you mean resurfacing? SUV's are prone to having these vibrating issues as the mileage racks up when braking. All it needs is resurfacing of the rotors. I have the same problem right now but have been putting off resurfacing the rotors.
'11 Toyota Camry LE V6 (Daily Whip) '10 Toyota Corolla S 5spd (Traded for Camry) '09 Honda Pilot 4WD Touring w/ RES (Kidmobile) '08 Lexus GS350 ML/NAV (Garage Dust Collector) '07 Nissan Altima SE V6 (Traded for GS) '05 MBZ SLK55 AMG (Lemoned 2/1/2010 )'03 Nissan 350Z Performance (Former Garage Queen) - SOLD |
2010 Honda Pilot EXL 4X4 / Polished Metal Metallic 2008 Acura TL / Nighthawk Black Pearl 1973 Triumph Spitfire / just 'cuz! |
#9 (permalink) | |
Here's a great video:
