Hello everyone,
I need a floor jack for changing tires and like the lightweight aspect of the tire rack item: Tire Rack Aluminum Service Jack However, it has a long handle and I only have about 3 feet between my cars and the garage walls. Anyone with long handled experience know if this will be a problem? Would I just need to turn the jack at an angle? Or would I be constantly fighting against hitting the handle on the wall? Thanks, Eric
2011 Pilot Touring, Silver, Black Leather, Premium Running Boards, OEM Remote Start, All-Weather Mats, Cargo Liner, Cargo Tray, Cargo Dividers. |
Have used and owned both longer and shorter handled jacks over the years. The longer jack makes it easier if you're going to move the vehicle while on the jack, and for jacking-up from underneath the vehicle (like if you'll use the differential as your lifting point). I've run into space issues, but like you suggested, you just attack it at an angle.
Having said that, the shorter handle is much easier to use in tighter areas. I'm sure you also read the reviews, but I thought this was interesting, "It’s a pretty big jack so if you’re planning on taking it to the Autocross or track day make sure you have the space. -Takes a few extra pumps to raise the car compared to others I’ve used."
Ed F '03 Havasu Blue EX-L - gone but not forgotten '06 Accord Pearl Gray EX-L '11 Dark Cherry Touring |
Wonder if I could just cut the handle down, or if that would make pumping difficult. I won't be transporting the jack or moving the vehicle while jacked.
I have a full size jack, steel though, not aluminum. Franky, you'll be suffering with only 3 feet of clearance. As for cutting down the handle I think that's a nonstarter. These jacks are designed to lift fast, which means extra effort on your part. As for going in at an angle, it's doable but I've never felt it was very stable. Can you just work outside?
Current Vehicles: '11 Pilot LX 4wd; '10 Subaru Outback 3.6R; '02 Honda Shadow 750; Pilot v. Outback: http://ohmahdeehness.wordpress.com/2...-two-vehicles/ |
nah, I live in vermont and my snow tire changeovers usually take place in late november on a slushy or snowy night or in march/april when it is still quite cold outside.
I am of the semi-informed opinion that there are jacking points in the center of the vehicle that might allow the use of a jack from the front/rear of the car. Check the owners manual, maybe? There is a picture in this thread. 2009 Pilot Jack and Stand Points
Sorry if I'm missing the point. Front to back at least you could have the working end under cover.
