2012 Wheel Lug Torque Spec - Honda Pilot - Honda Pilot Forums
Old 10-28-2011, 05:23 PM   #1 (permalink)
Default 2012 Wheel Lug Torque Spec
Anybody know the wheel lug torque spec for the 18" wheels on the 2012 Pilot? I found the torque for the spare in the manual. It is 94 ft-lb. But that is considerably higher than the 80 ft-lbs. for my 2004.
Old 10-28-2011, 06:08 PM   #2 (permalink)
Why don't you trust the manual? Granted it is a bit higher, but it's also a completely different vehicle than your 2004.
Old 10-28-2011, 09:41 PM   #3 (permalink)
Uhm -because like I noted, the manual gives the torque rating for the spare but not the regular alloy wheels. Am I supposed to assume that the 18" alloy rims get the same torque spec as the steel wheel used on the spare?
Old 10-29-2011, 03:29 PM   #4 (permalink)
Yes, it's the same.
The alloy wheels have steel inserts where the lug nut makes contact.
