2010 Pilot Touring - Honda Pilot - Honda Pilot Forums
Old 10-19-2011, 12:03 PM   #1 (permalink)
Default 2010 Pilot Touring
Pls help!
Does anyone had expirienced that when in reverse the mirror should tilt down.Ours did not tilt down but instead went up until it was stuck and giving out a very loud clicking noise.called our local dealer and was told that they have not heared of such thing happening... Scheduled an appt for next week...
cocoy perey is offline   Reply With Quote
Old 10-19-2011, 12:19 PM   #2 (permalink)
RSQ Pilot's Avatar
Garage
Originally Posted by cocoy perey View Post
Pls help!
Sounds like the mirror may be jambed...
Has it ever worked properly?
Has someone inadvertently tried to adjust the mirror while it was being automatically being tiled down?
Have you moved the L-R outside mirror control to the center position to shut off the 'in-reverse tilt down' feature then turned it back on and readjusted the mirror to a normal position; then flip the control, engage reverse and seen if it now tilts down on the affected side?
Old 10-19-2011, 01:10 PM   #3 (permalink)
Thank you for your reply.I did all the things you had mentioned.Yes it was in working order until it happened five days ago.No one tried to adjust the mirror while it was in-reverse tilt down mode.so far it happened on three occations ..
Old 10-19-2011, 01:21 PM   #4 (permalink)
RSQ Pilot's Avatar
Garage
dealer time
Old 10-19-2011, 01:48 PM   #5 (permalink)
Wonder if the affected mirror goes down when shifting from reverse to drive? ( opposite of what it's supposed to).
Rob
