Pilot vs mdx towing - Honda Pilot - Honda Pilot Forums
Old 10-09-2011, 10:25 PM   #1 (permalink)
Default Pilot vs mdx towing
Was lookng at owners manual for 11 pilot and 11 mdx and saw the mdx is rated for 5000 lbs trailer towing. Other than the engine, why the difference?
osudelt69 is offline   Reply With Quote
Old 10-09-2011, 10:38 PM   #2 (permalink)
Frame, brakes, axle, tire and wheel load ratings. Incremental differences in all of those things will allow for a higher trailer tow rating.
2011 WDP/Black Touring 4WD
2008 Toyota Prius Touring
2007 Mazda MX-5
pearsonrj is offline   Reply With Quote
Old 10-10-2011, 05:00 AM   #3 (permalink)
They share those parts.
Other reasons for the difference. Marketing?
Old 10-10-2011, 09:02 AM   #4 (permalink)
RSQ Pilot's Avatar
Garage
More power....MDX has more hp and low end torque
Old 10-10-2011, 07:43 PM   #5 (permalink)
iggibar's Avatar
They have different drive systems. That alone is enough to cover the differences. The MDX has permanent awd, which helps in its own.
2011 Honda Pilot EX-4WD. [bought]
2011 Honda Accord Crosstour EXL-4WD. [leased]
2009 Ford Focus SE. [bought]
iggibar is offline   Reply With Quote
Old 10-10-2011, 07:46 PM   #6 (permalink)
RSQ Pilot's Avatar
Garage
What's 500 lbs among friends????
Old 10-10-2011, 08:06 PM   #7 (permalink)
LOL its not but its the difference between buying a 20 and 21 ft boat
I did notice in the manual that when measuring the rear suspension for tongue weight, the MDX sags less under weight, probably due to tighter suspension tuning??
Old 10-10-2011, 09:24 PM   #8 (permalink)
RSQ Pilot's Avatar
Garage
Gross tow weight will include all gear, fuel and other junk thrown in with the boat and trailer. Then consider all gear and occupant weight of the Pilot or MDX and subtract all that from the gross combination weight rating of the tow vehicle and you may want a smaller boat.
Old 10-11-2011, 07:42 AM   #9 (permalink)
Is there any chance that a MDX weighs a few hundred pounds less than a Pilot?
Anyone have the vehicle weights handy?
Old 10-11-2011, 08:43 AM   #10 (permalink)
RSQ Pilot's Avatar
Garage
2011 Acura MDX | Specifications | Acura.com
2011 Used Honda Pilot Specifications - Honda Certified Used Cars
Old 10-11-2011, 08:49 AM   #11 (permalink)
Two rating include how quickly the vehicle can accelerate the allowed weight.
A little power could change which side of a marginal performance specification the vehicle is on.
Old 10-12-2011, 02:40 PM   #12 (permalink)
The MDX has 50 HP and 17 lb/ft of torque more than the Pilot.
the MDX also has a 6 speed transmission with a lower 1st gear for better torque multiplication. 3.36 1st and 2.10 2nd gear vs. 2.697 and 1.606 2nd for the Pilot.
Even with the Pilots slightly shorter final drive ratio, the MDX has shorter gearing thru out and probably is the biggest factor in the higher towing capacity
