5300 miles on my ex 4wd. It has done this since just about new. High pitched squeak. Like styro foam in the dash or between the panels. Sometimes sounds like behind the gear shifter other times seems in the cluster. Can't quite tell. Anybody else with this or a fix? Usually on coarse pavement or when there is body flex.
My wife's developed a squeak (the first one we've ever had with our Honda products!) and was more prevalent in cold weather and the few times it sits outside overnight. I traced it to the actual gear shift lever - if I put my hand on it, it would stop. But once warmer weather hit, it doesn't do it. I'm waiting to see if it comes back this fall/winter...
2011 Taffeta White Pilot EX-L AWD 2011 Celestial Blue Metallic Fit Sport 5MT |
If I stick my finger between the console and dash, I can stop the squeak. At least I found it! Mostly goes away when warm. When cold it is aweful.
I have a vibration in the steering wheel pad cover(where the horn and airbag are). It only happens on rough pavement. Just pulling or pressing on the backside of the steering wheel cover will stop the noise.
2011 Pilot EXL 4WD, White |
