Glass hatch not opening - Honda Pilot - Honda Pilot Forums
Old 11-24-2010, 08:47 AM   #1 (permalink)
Default Glass hatch not opening
The Glass hatch on my Pilot 2011 is refusing to open.
1) from the remote.
2) switch on the drivers door.
3) button under the handle tailgate.
It was working fine until I got the firmware update for the moonroof battery drain/closure issue. Now it has stopped working has anyone else come across a simmilar problem? and how do you access the glass hatch lock mechanism
PS I have checked the Fuse under the secondary fusebox and it is ok
dappodan1 is offline   Reply With Quote
Old 11-24-2010, 09:17 AM   #2 (permalink)
cwa107's Avatar
I'd imagine the interior trim panel will need to be pulled.
But quite honestly, it should be under warranty. Take it into the dealer and let them repair it.
2013 Nissan Pathfinder SL Premium, Dark Slate
2010 Honda Pilot EX-L 4WD (traded)
Old 11-24-2010, 09:41 AM   #3 (permalink)
cwa107's Avatar
Originally Posted by RSQ Pilot View Post
Unless they changed things on the 2011, the lift up hatch glass is not controlled by the remote, the tailgate handle button or the driver's control button, they only operate the tailgate release. The glass hatch only opens with the button under the chrome trim to the right of the license plate...check your OM for specifics.
That's probably specific to the Touring since it has a power-operated hatch.
The lesser models (like my EX-L) have a button on the remote that pops the hatch glass portion remotely.
Old 11-24-2010, 09:46 AM   #4 (permalink)
RSQ Pilot's Avatar
Garage
Disregard my comment, I was wrong () and deleted that post.
Old 08-05-2011, 09:32 AM   #5 (permalink)
Default 2010 Pilot glass hatch
The button to open the glass hatch on my 2010 Pilot EX-L sometimes works and sometimes doesn't work. Whether the button works or not, there is always a clicking sound from the lock area. Mentioned to dealer while vehicle was in for routine service and of course the button worked. Dealer hadn't heard of this problem.
Any suggestions?
Cmoor is offline   Reply With Quote
Old 08-05-2011, 10:14 AM   #6 (permalink)
cwa107's Avatar
Any suggestions?
I've had this happen to me a time or two. It tends to happen when the sun is beating on the back of my car. If I push the button and pull on the handle (on the glass, not the hatch) at the same time, it always opens with some force.
That leads me to believe that when the seal is warmed up, it gets sticky - and so when the latch releases, there's not enough spring or play in the hinges to actually release the stay from the latch. If you apply some force, it's enough to free it when the latch releases.
If this is happening often, what you might consider doing is applying some kind of lubricant or treatment to the rubber gasket around the glass. Even something like ArmorAll might help with that.
