I know this topic has been discussed but the 2009-2010 model is now a year old so I wanted to know what are you guys getting out there.
I am still getting a little less than 300 miles on a full tank. and that is freeway driving.City driving is way less.
'09 Touring 4x4, Nimbus Grey with Black interior, Rear Entertainment, Dark wood trim all around, Lighted side step, Chrome Grill, Aluminum front and back under side, Window guards, All weather floor mats!! |
Miles per tank is about the worst way to track milage.
I did a test last weekend about mpg. The conclusion...if you drive slow and stopping less you'll get more bang for the buck. I drove on the highway at 10-15 miles less then the posted sign and I didn't gas pedal when going down hill. I also use neutral and coast before I come up to a stop light/sign. I manage to get 23.3 per gallon. So driving slower and using neutral gear for coasting will help your gas mileage.
Apart from the driving habits, city or freeway driving, coasting or not coasting, putting in Neutral on downhill, and other tweaks, what is your milage?
It also depends if you have a 2WD or 4WD. I am sure most everyone keeps track of how many miles they got per full tank. So lets just do a poll of what people are getting. Thanks
Straight-up highway travel on Shell 87, loaded for vacation, A/C on the entire time, the Pilot gave me 21.7mpg. On cheaper stuff it was about 20.9. Tires were inflated to 36psi and probably should've done 38-40psi, but given the load and heat, I didn't want to go there.
Daily driving in town (the wife's style), maybe 18-19mpg, but that is all short trip, stop and go, traffic light driving.
2009 DCP Touring, Navi & RES 2004 Acura TSX (bunch of mods b/c its fun) 2008 Ducati 1098 R.I.P. |
On my first tank of gas since I purchased the vehicle new a wee and a half ago, I got 20.4 MPG hand calculated and that was driving about 75% highway at about 72mph and about 25% city driving. Not too bad for it's first tank. I will post the numbers on my second fill up at the end of this weekend. Hopefully it will be as good or better because that's about what are driving habits are.
2011 Pilot EXL w/RES Silver 2010 Dodge Ram 3500 Laramie Crew Cab 4x4 2010 Open Range 399BHS |
First we don't know how "full" each persons "Full" is.
Even if everyone always stopped filling at the "first click" it is not the same for every car or every pump or every time. Even if we assume it is the same for every car, pump, and time; we don't know how empty everyone considers their "Empty". Is it when they start feeling it is; "Too Low", When the light comes on, When the gauge in on "E". Below "E"? Even if everyone agreed that it is the same point on the gauge; We don't know how far each person drove after getting to that point before getting gas. Plus when looking at "Miles per talk" people focus on the "Best" or what they "Feel is the average", making any valid comparisons of something that is as variable as fuel consumption completely impossible.
However beautiful the strategy, you should occasionally look at the results. Sir Winston Churchill Last edited by N_Jay; 09-02-2010 at 08:34 AM. |
#9 (permalink) | |
On most vehicles these days coasting in neutral uses more gas then leaving it in gear since they shut off fuel completely when not needed.
#11 (permalink) | |
#12 (permalink) | |
If you mean ambient temperature with regards to A/C usage, clearly you are going to use the A/C more with an ambient temperature of 100F outside verses 75F while driving. In either case, they are part of the load on the motor and effect mpg.
#13 (permalink) | |
"Miles per tank" is about the worst way to track milage.
#14 (permalink) | |
I was addressing this part; "Tires were inflated to 36psi and probably should've done 38-40psi, but given the load and heat, I didn't want to go there." The greater the "cold" inflation, the less the temperature rise with use. The greater the load, the greater the temperature rise with use. Ac has nothing to do with tire temps or rise. Pressure build due to temp rise from use is already taken into account when calculating proper and maximum tire pressures.
However beautiful the strategy, you should occasionally look at the results. Sir Winston Churchill Last edited by N_Jay; 09-02-2010 at 10:59 AM. |
#15 (permalink) |
If it helps the OP, attached is a summary of my mileage since May. This is based on a CSV file generated from 'Mileage' for Android.
Most of my driving (90%) is stop-and-go. You'll notice the last tank hit a high of 20.5 - that was a nearly all highway drive to Atlantic City and back. HTH.... http://home.comcast.net/~cwa107/files/mileage.xls
