New iPhone update (iOS4) not compatible with Pilot navigation system! - Honda Pilot - Honda Pilot Forums
Old 06-22-2010, 10:05 PM   #1 (permalink)
Default New iPhone update (iOS4) not compatible with Pilot navigation system!
I've been using my iphone 3GS with version 3.1.3 software for a while now without issues. Yesterday I updated my software to version 4 and now when I connect the phone to the USB port, it shows that its not compatible!! Argh!
I miss the ability to control my iPhone through the car's navigation system.
Becareful and really think about it before you upgrade. Anyone else have this happen? Is there a solution???
Thanks,
John
johnny0723 is offline   Reply With Quote
Old 06-23-2010, 03:25 AM   #2 (permalink)
My 3GS w/ iOS 4 still works the same as it always has. I still get the initial "This accessory is not supported" message on the iPhone itself (just like on the 3.x software) but that is nothing new. The Honda's iPod interface still works fine with it. Maybe you need to reset your phone? (hold home button and power button simultaneously until you see the Apple logo). What year Pilot do you have? Mine is a '10. If yours is an '09 model, that might explain the difference.
2012 Pilot Touring 4WD RES -- Polished Metal Metallic, black interior. OEM options: chrome side steps, air deflector, roof rack cross bars
Previous Pilots: 2003 EX 2WD, 2005 EX-L 4WD RES, 2007 EX-L 4WD NAV, 2010 Touring 4WD RES
HenryBravo is offline   Reply With Quote
Old 06-23-2010, 07:14 AM   #3 (permalink)
I am having the same problem as John. I am encouraged by Henry as I have the 2010 Pilot too - so it should work. Unless there is a software compatibility difference within the model year. Going to try the rest option a see what happens....
mjpierson is offline   Reply With Quote
Old 06-23-2010, 04:32 PM   #4 (permalink)
Now I'm really nervous....will upgrade my 3G uh..now..especially since I plan on being on line first thing in the morning for the new phone.
TriKKy is offline   Reply With Quote
Old 06-23-2010, 05:52 PM   #5 (permalink)
I have a 2009 (purchased in Aug 08') and my 3GS with iOS4 works great. I can still scroll through songs using the Honda navigation bar.
My iOS4 also allows multi-task (safari, email, facebook, etc) on the phone while I am connected to the Honda ipod doc. I can also use Pandora and mulitask simultaneously however I can only control the Pandora songs on the iPhone.
09' Pilot Touring 4wd - Sterling gray/gray - 35%/20% tint (front/sunroof) - OEM remote starter - Full size spare - Premium running boards - OEM fender trim - OEM crossbars - HID headlights and foglights - debadged - LED puddle lights
01' Audi S4 - Imola Yellow - Stg II
bdac2k is offline   Reply With Quote
Old 06-23-2010, 07:13 PM   #6 (permalink)
3G + iOS4 = Working on 11 Pilot
Old 06-23-2010, 10:46 PM   #7 (permalink)
I have an '09 touring 4WD. Resetting the phone works!!! I'm so relieved...thanks for the suggestion!
Old 06-24-2010, 09:46 PM   #8 (permalink)
Very pleased (on many levels) to report that the iPhone 4 works without any issues.
It's also very nice to note that they have changed the "nag" message when you connect it from the message giving you the option to turn on Airplane mode (or not) to just a message letting you know some crap and then only ONE "Dismiss" button.
Old 06-24-2010, 11:42 PM   #9 (permalink)
I just picked up my iPhone 4 this afternoon. I can't wait to try it out as well.
Old 06-28-2010, 01:59 AM   #10 (permalink)
both iPhone 4s integrated without a problem...nice!
2011 Pilot EX-L + Navi
2001 911 TT
2005 Cayenne S +PASM
911TwinTurbo is offline   Reply With Quote
Old 07-06-2010, 01:37 AM   #11 (permalink)
Default Reset worked, thank you!
HenryBravo, thanks for the post suggesting iphone reset. I was getting the annoying "Unsupported" message on my '10 Pilot radio after updating my 3G S firmware to 4.0. Tasting life without pandora in my pilot was dreadful (kids upset also!), and now after the reset I'm back in business.
polishedmetal is offline   Reply With Quote
Old 07-06-2010, 10:50 PM   #12 (permalink)
Glad to help!
Old 07-28-2010, 11:27 PM   #13 (permalink)
I am having same problem. 3gs and 4.0.1 How do I go about updating firmware in car. Is there a trusted site out there? TX
themookman is offline   Reply With Quote
Old 07-29-2010, 12:46 AM   #14 (permalink)
The hard reset mentioned above did not fix your problem? Also, make sure the ignition key is in the off position when you plug in your phone, as it seems to initialize better that way.
There is no software update for the Pilot at this time to improve iOS4 compatibility. The Pilot interface w/ iOS 4 does seem to be a bit buggy at times based on my experience.
Old 08-18-2010, 02:40 PM   #15 (permalink)
My iphone 4 does not work when plugged in to the usb either....now before i do a reset...what happens when you reset the iphone?? I have a jailbroken phone will i lose anything?? Any help would be appreciated...as I'm hesitant to "reset"
2009 TAFFETA WHITE 4WD Touring w/res & Nav
fishdogg is offline   Reply With Quote
