Service codes, Can you decifer them here? - Honda Pilot - Honda Pilot Forums
post #1 of 8 (permalink) Old 05-10-2010, 01:21 PM Thread Starter
09Touring4x4's Avatar
I have a service code on the MM " B16".
I know that is for Oil change... But I was wondering if it is for the VTM-4 also or not.
Does anyone have a code cheat sheet?
TIA
Cheers!
'09 Touring 4x4, Nimbus Grey with Black interior, Rear Entertainment, Dark wood trim all around, Lighted side step, Chrome Grill, Aluminum front and back under side, Window guards, All weather floor mats!!
09Touring4x4 is offline
post #2 of 8 (permalink) Old 05-10-2010, 02:06 PM
RSQ Pilot's Avatar
Garage
TIA
Cheers!
Owners manual has codes as does the Honda Owner Link web site for which you can register.
B Oil and filter and various system and component inspections
1 rotate tires
6 vtm-4 service ( other items dependent on time/use like 3 yr brake fluid)
2009 Pilot Touring RES 4wd Mocha Metallic; OEM Premium Running Boards, OEM cargo tray, Weathertech Floor Liners, H-9 LB mod, Michelin Defender LTX M/S @ 82K, full size LTX spare w/OEM rim, AVS Bugflector II
RSQ Pilot is offline
post #3 of 8 (permalink) Old 05-10-2010, 03:05 PM Thread Starter
1 rotate tires
Thanks... Just read the Manual also.
The Speed of Dark?
Same as the speed of light as when the light leaves dark arrives! :
post #4 of 8 (permalink) Old 05-10-2010, 09:25 PM
My OBDII code reader doesn't work on the 09 Touring. It is the small handheld one which works fine on my 04 TSX. Anyone have a similar experience or is mine just too cheap to work. I bought it off a Mac Tools truck a few years ago as something quick and very portable having removed my cat in swap for a hi-flow one and needing to reset codes. A simple anti-fouler fixed that issue, but none-the-less been curious why my reader doesn't work on the Pilot.
2009 DCP Touring, Navi & RES
2008 Ducati 1098 R.I.P.
moda_way is offline
post #5 of 8 (permalink) Old 05-12-2010, 12:39 AM
theirishscion's Avatar
Almost certainly for the same reason my old (2002-ish) code reader won't work on my new Pilot or my wife's 2007 MINI Cooper, I think the new cars do their OBD communication over a CAN Bus interface rather than one of the other older protocols. Any new-ish CAN compliant code reader/resetter should work just fine.
Fairly exhaustive detail available here and a quick read suggests that CAN Bus is the new federal standard, so it looks like getting a new reader should be a fairly long last investment. Might have to do that.
2011 Touring 4x4 RES, Dark Cherry Pearl & Beige. "The HDMI Wagon"
2014 Subaru Impreza WRX STI 5-door, Suspiciously Glittery White. "The Guinea Pig" (or less charitably "The Midlife Crisis")
2008 Acura RDX w/ Tech package, Boring Dark Grey. "The Red Headed Stepchild"
theirishscion is offline
post #6 of 8 (permalink) Old 05-12-2010, 10:53 AM
Site Sponsor
hondacuraplanet's Avatar
I have that exact same reader, the ET-80. Have you used yours with a PC interface?
hondacuraplanet is offline
post #7 of 8 (permalink) Old 05-12-2010, 01:41 PM
Actually, mine is the ET50, although it doesn't look like the current one online. It is black and 2 button, but it has a full LCD screen and covers more than what is mentioned on MAC tools currently. Not sure I understand what you mean by a PC interface.
moda_way is offline
post #8 of 8 (permalink) Old 05-13-2010, 08:00 AM
Site Sponsor
There's software that will allow it to interface with a PC. I'm just not sure exactly what it does when the software is used with it.....didn't know if you had any experience with that.
