![]() Join Date: Aug 2008
my white Pilot EX-L with premium running boards installed myself. I haven't installed the rivnut but it's secure enough with the other 5 bolds put in. My next project is the EOM grill and rear metal cover.
09 Pilot EX-L Premium running boards |
Nice looking. Whaich running boards are those -- premium?
-Dan
2009 Honda Pilot Touring w/Nav/Res 1991 Volvo 940se 15G 23 PSI "Slepa Brick" 1986 Porsche 944 N/A |
Yes Premium without lights. I think it's the best looking one out of the four you can get for the pilot. If you're ordering online get it from Bernardiparts.com $450 + 20 shipping or do what I did...print it out and have you're dealership price match. I couldn't wait to put it on. I definitely recommend these for accessories....changes the look by a lot.
FYI ...since you're in MA...bernardi is in framingham...Be sure to call you're local hOnda stealership and verify they it in stock. herb chambers in burlington is where i got mine. Boch didn't have any in stock but was willing to honor the price match. If you don't have the riv nut tool install all bolts according to direction and take it back to the dealership and let them know you're running board is missing a bolt because you discovered it was loose. They will think you're pilot came with them. Boch quoted me at $800 with install. do it yourself or if your around my area I can help you.
Do you think that rivnut tool is available somewhere?
Is the metal finish on the premium running board shiny or a brushed (matte) finish? I'm thinking it may not match the chrome-looking side moldings on the Touring model. |
Hey jake. Nice, kinda dark on the picture but I believe it looks impressive. just have a question on installation. Is it a bolted on installation without disassemble of the interior? because my mom is having a difficult time enter and exiting . I was thinking about installing one myself. I had viewed the diagram on the site you refered. any comments would be greatly appreciated.
This video should make installation of running boards much easier...
youtube more installation info directions can be found at: collegehillshonda.com and diyhonda.com
09' Pilot Touring 4wd - Sterling gray/gray - 35%/20% tint (front/sunroof) - OEM remote starter - Full size spare - Premium running boards - OEM fender trim - OEM crossbars - debadged |
Just completed installation of premium running. Fairly simple install took about an hour doing it alone. Found another shortcut for the riv nut install. I will upload photos and description of what simple tools I used a little later.
Boards look great!
Just order the 2nd row cover and floor mats and running board. I will need to get the rivet gun? what is the secret without using the rivet gun?
Ben
2011 WRX Sedan 2009 Pilot Touring 2006 EVO 9MR GG Sold 2004 S2000 SS Sold |
Poor man’s riv-nut tool:
o One 8mm socket head bolt 8mm-1.25x40 o 8mm nut with one side marked as an index point o 8mm washer o 6mm Metric hex (allen) wrench • There are only 2 riv-nuts in the install at the rear brackets in an outboard frame hole (must have been an engineering oversite all others used are factory threaded). BTW all OEM kit nuts and bolts for this install use a 13mm wrench and/or socket.
A couple of other thoughts:
Premium Black Running Boards • First Download installation instructions from a site like : http://www.bernardiparts.com/Images/...s_AII39395.pdf OR http://www.estore.honda.com/aii/aii0...odelname=Pilot o None came with my shipment • Make sure your have the correct metric socket and wrench. 13mm works all nuts and bolts and the riv-nut device • If you don’t have torque wrench ….borrow a friend’s… over tightening the T-head bolts in the plastic running board grooves can cause damage, Too loose and they'll vibrate out. The metal frame brackets are more forgiving but why risk stripping out a thread. Spent about $1.75 at the hardware store, $0.92 for the 8mm-1.25x40 socket head bolt, and a 5 pack each for the 8mm nuts and washers as the didn't have singles.
