Pic of plugs from 2009 Pilot - Honda Pilot - Honda Pilot Forums
post #1 of 5 (permalink) Old 03-19-2017, 10:24 PM Thread Starter
I have attached a photo of the plugs that I removed from my 2009 Pilot EX-L today.
They have 40k miles on them and 158k on the vehicle.
Notice how fouled plugs 1 and 2 are. I had to take out #1 due to a misfire.
#1 Looks absolutely terrible. It was wet with oil and was grimy.
I took out my plugs from my 2002 Toyota Echo with 268k miles not long ago, and they looked as I would expect - just regular wear. Far and away better than the Pilot.
PilotError is offline
post #2 of 5 (permalink) Old 03-20-2017, 01:47 AM
plplplpl's Avatar
Garage
I've seen worse: Name That Engine Noise (Video)
There seems to be mounting anecdotal evidence that plugs have a tendency to back out in Pilots, and that re-torquing plugs to spec should maybe be a maintenance item.
2006 EX-L w/RES (black)
(green);
(red);
, see avatar] (black);
(gray);
(blue);
(burgundy);
plplplpl is offline
post #3 of 5 (permalink) Old 03-20-2017, 06:49 PM
any excessive oil consumption? Do you have the VCM Muzzler installed?
thefisch is offline
post #4 of 5 (permalink) Old 03-20-2017, 08:51 PM Thread Starter
I did have excessive oil consumption (4 oz per week), but I installed the Muzzler in the last 5-6 days. I will check the oil level in a few more days.
Muzzler is working well. The ECO light has flashed just once two days ago.
The Pilot is my wife's vehicle. She told me today that it has more pick up now than it did before I put the Muzzler on and changed the spark plugs. I have recently changed the air filter and oil too. Basic stuff.
post #5 of 5 (permalink) Old 03-20-2017, 10:26 PM
The Muzzler will likely fix the plug fouling. It may take a while before the oil consumption lessens, if it lessens at all. The oil consumption is probably due to dirty piston rings. One thing to note, is that many of these vehicles are under extended warranty for this issue. It's 8 years and unlimited mileage but you have to go in with a misfire code stored on cylinders 1, 2, 3, or 4. They will change the plugs and do a PCM software update and if it happens again they will replace the piston rings.
John_Clark is offline
