Codes P0306 and P2279 - Honda Pilot - Honda Pilot Forums
Old 01-29-2013, 08:26 AM   #1 (permalink)
Default Codes P0306 and P2279
I have an 05 with roughly 150k miles on it. I started getting codes P0306 and P2279. Changing all of the spark plugs and replacing the coil pack on cylinder #6 seems to have taken care of code P0306. I also recently cleaned the throttle body, removed and cleaned the ERG valve, and cleaned the upper intake manifold. I used carb cleaner on all of the hoses looking for a vacuum leak but didn't find anything. Any suggestions for what might be causing code P2279?
I have also been experiencing rough starts, mostly when the truck has been sitting overnight and it is cold out, and the VTM has been coming on. The VTM light usually turns off after the truck has warmed up or at the second start up of the day.
Any help or ideas would be great, Thanks!
JBs Pilot is offline   Reply With Quote
Old 01-29-2013, 08:36 AM   #2 (permalink)
GuineusMaximus's Avatar
Sounds like you have a function issue with your PCV Valve since you have stated you found no issues with any of your hoses.
GuineusMaximus is offline   Reply With Quote
Old 02-01-2013, 12:18 AM   #3 (permalink)
Ok I will try replacing my PCV valve. What fails with the PCV valve that make the computer throw a code for a vacuum leak?
Old 02-01-2013, 08:12 AM   #4 (permalink)
If you hear the ball moving in it then it should be ok, check for vacuum leaks at these parts:
PCV valve
PCV hose
Purge (PCS) line
Throttle body
Intake manifold
Brake booster hose
Old 02-01-2013, 10:46 AM   #5 (permalink)
94eg!'s Avatar
Did you check the VTM system code you are getting? If not use the paper-clip trick to find out what's going on----> VTM light on 2003 Pilot
HE>I
Old 02-01-2013, 10:52 AM   #6 (permalink)
If you need more info on the codes that are being thrown, check out my Auto Enginuity tester. Its a very useful tool for diagnosing issues!
FS: Auto Enginuity OBD2 Scan Tool w/ Laptop
jarvo2 is offline   Reply With Quote
Old 02-01-2013, 05:08 PM   #7 (permalink)
94eg!'s Avatar
$220?!?!?! You can get free apps for your smart phone (called Torque) to do the same thing. All you need to do is buy a blue-tooth adapter for your OBD2 port from Amazon for $25.
Of course a paperclip + internet is free.
HE>I
Old 03-20-2013, 07:01 PM   #8 (permalink)
Unhappy
Ok I have tried the PCV valve and hose, checked the throttle body, brake booster hose, and the intake manifold. I still can't seem to find this vacuum leak. What sensor would be throwing code- P2279? I am guessing it is faulty??
Old 03-21-2013, 10:09 AM   #9 (permalink)
May be time to look deeper, the vacuum leak could be anywhere on the vacuum side of the engine. A Cracked intake manifold, head, or gaskets for them. Expand your search area.
Lvoffroader is offline   Reply With Quote
Old 05-14-2013, 11:23 PM   #10 (permalink)
code table: Diagnostic Trouble Code Table
sdfsfs is offline   Reply With Quote
