Those rear 3 spark plugs... - Honda Pilot - Honda Pilot Forums
Old 01-13-2013, 05:34 PM   #1 (permalink)
Default Those rear 3 spark plugs...
Started replacing the spark plugs on my '07 Pilot. The old thread posted by Skamp is very helpful, but after changing the front 3 plugs, I've arrived at the back three(closest to the dashboard). Is there a trick to getting access to those plugs? I can barely see the coil packs, and in fact can locate only 2 of them. Do I need a mirror set up along the back wall to do this? Thanks in advance.
swami7774 is offline   Reply With Quote
Old 01-13-2013, 06:13 PM   #2 (permalink)
I did mine one month ago. No, you don't need a mirror, I did mine by touch. Having done the front 3 first you should have a feel for how the parts fit together.
Long arms will help, good luck.
97trophy is offline   Reply With Quote
Old 01-13-2013, 06:32 PM   #3 (permalink)
My arms are pretty long. I'll give it a shot. I'm just concerned about dropping stuff behind the engine.
Old 01-13-2013, 08:30 PM   #4 (permalink)
KKL
I threw a blanket on top of the intake, climbed up and knelt on it to do the back 3 plugs.
KKL is offline   Reply With Quote
Old 01-13-2013, 08:48 PM   #5 (permalink)
Yeah, I might have to do something like that. Thanks!
Old 01-13-2013, 11:13 PM   #6 (permalink)
Wish someone had told me this: be VERY CAREFUL when removing the back side spark plugs. The tight access makes it hard to hold your wrench perfectly straight in this job. I nearly stripped out #1 plug, its thread was badly corroded for some odd reason (it wasn't very tight) - the other 5 were clean and shiny. I was able to use a torque wrench to get them "just right" hopefully prevent corrosion in the future. Good luck!
Petecomp1 is offline   Reply With Quote
Old 01-14-2013, 04:13 PM   #7 (permalink)
use 2 small 3 inch extensions when removing them. when the first one bottoms out when coming out, then remove it and the rest will come out with no issues. be sure to use anti seize paste when putting them back in.
azthundercloud is offline   Reply With Quote
Old 01-14-2013, 05:41 PM   #8 (permalink)
Not all plugs require that paste. NGK say do not use it.
http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
Old 01-14-2013, 06:40 PM   #9 (permalink)
Don't be afraid to lay across the top of the radiator and engine to reach those rear plugs. That is much easier than trying to be a contortionist and working by feel only.
Old 01-15-2013, 03:00 PM   #10 (permalink)
I used a step stool to give me a little more height. Then kind of layed across the engine, and was able to see. I also had a couple plugs that were pretty tight. The 2 extensions method worked well, it is a tight fit back there. Just take your time, and complete one plug at a time.
I also used a little anti-seize on the new plugs.
Good luck.
DB
DB77 is offline   Reply With Quote
Old 02-24-2013, 02:33 PM   #11 (permalink)
Wasn't as hard as I first anticipated. I put some padding on the hood latch area, and just laid down across the engine bay. I was able to get right up in there, and see the coils & bolts just fine.
69SKYDIVER69 is offline   Reply With Quote
Old 02-26-2013, 12:04 PM   #12 (permalink)
I did use a mirror just to have a look at the setup, then put it aside. I was afraid I would knock it down and it would get stuck there.
It's not so hard. Using 2 short extensions on your wrench definitely is the way to go.
2005 Pilot EX-L
2012 CR-V EX-L
2012 Rav4 Limited V6
normkol is offline   Reply With Quote
Old 02-27-2013, 10:25 AM   #13 (permalink)
What is the torque setting for installing the plugs?
tarzan17 is offline   Reply With Quote
Old 02-27-2013, 04:01 PM   #14 (permalink)
156 in-lbs.
