*Need more stickies for common problems* - Honda Pilot - Honda Pilot Forums
Old 01-02-2013, 10:04 PM   #1 (permalink)
Default *Need more stickies for common problems*
there are several common problems with our 2003-2008 Pilots that could save a lot of searching and repeated questions if we'd just save more stickies.
Thusfar, in 5 months of ownership, I've had to do extensive researching to find info and repair these common issues;
*HVAC control panel backlights
*Radiator leak / transmission cooler issues
*dome light assembly repair / replacement
what other common issues are there that need a STICKY?
ahoy is offline   Reply With Quote
Old 01-02-2013, 11:57 PM   #2 (permalink)
3 to 5 members having same or similar doesn't make for common problems.
Old 01-03-2013, 09:14 PM   #3 (permalink)
take your own frequent advice and "use the search function."
you're right. it's the VOLUMINOUS NUMBER of repeated requests for these same items that make them common problems.
Old 01-03-2013, 10:03 PM   #4 (permalink)
So for every problem that more than 4 or 5 people have then there should be a sticky then? Yeah, that makes a whole lot of sense. The whole forum would be full of stickies then.
Old 01-03-2013, 10:29 PM   #5 (permalink)
yeah, "click here first n0oB!!!" with us having a SINGLE STICKY on our board. where should we click?!?!
Old 01-03-2013, 10:35 PM   #6 (permalink)
did you actually search "radiator leak" "climate control light" or this just today posted, Driver's Side Map light - not working??? ??
