Ok, the driver's side map light does not work when the driver's door is opened...but does work when you push it and manually turn it on.
I replaced the bulb and had no change. Has anyone had this condition? 2005 EX-L with Nav about 105k miles (Is it the driver's side door switch causing this?) Thanks!
2005 4WD EX-L Sagebrush 235/70-16 Firestone Destination A/T Monroe Sensa-Trac shocks on rear (p/n 58645) LED interior light kit including license plate LED's 2012 Big Red MUV (side-by-side) on a 6 x 10 utility trailer |
Hey, I've got this problem too. Just been living with it as a minor inconvenience. Hoping for a simple solution.
John G 2005 Pilot EX-L (RES), Steel Blue Metallic “What avail are forty freedoms without a blank spot on the map?” ― Aldo Leopold |
I had the exact problem. It's actually a fairly common problem for all Hondas that used the same lighting base. It's related to the contacts to turn the light on when the door is open.
I fixed it by replacing the part (34404-SDA-A21). Here's a thread that discusses it: Dome light problem The part runs about $35-40 if you order it online.
2005 Honda Pilot EX-L (Desert Rock Metallic, side steps, crossbars, rear splash guards, wheel locks, towing package, full-size spare on EX rim) 2007 Honda Accord EX-L V6 sedan (Alabaster Silver Metallic, splash guards, wheel locks) Last edited by sjlee; 01-02-2013 at 05:00 PM. |
If its only the driver side light that doesn't come on, and all other interior lights work when you open the driver door, then the door jamb switch probably won't fix that.
There is a micro switch underneath each lense of the overhead console light. When the switch goes bad, the light won't come on. You can remove the lenses, and remove the entire console with the light housing. You can then remove the micro switches, spray them with some electrical contact cleaner. It has helped me in the past with an Acura that had the same issue. If that doesn't help, you may be able to find replacement switches at the dealer. Last edited by 2010exl; 01-03-2013 at 02:47 PM. |
don't pay for parts yet - same assembly type...try the fix first;
Honda Ridgeline Owners Club Forums - View Single Post - One push button light above dash only works when pushed but not when doors open |
Thanks ahoy! |
Thanks for the tips.
I will take a look at this over the weekend and see what I can figure out.
2007 Pilot EX-L RES Formal Black w/ Saddle INT |
Bizarrely I had it to for a while. Then it fixed itself.
Weird stuff does happen Sent from my iPhone using AutoGuide.com App |
My switch went bad. It is an Alps switch and was only a couple bucks at Mouser.
2012 2WD Touring White Diamond Pearl / Grey 2006 2WD Steel Blue EX-L with Navigation (RIP - 3/10/12) -------------------------------------------------------- My goal in life is to be as good a person as my dog already thinks I am! |
I ended up putting in a new center dome light assembly and it fixed the issue.
I did try this: Honda Ridgeline Owners Club Forums - View Single Post - One push button light above dash only works when pushed but not when doors open But it did not fix the issue. Sorry for the late reply, thank you all!
