#18 (permalink) | |
2004 SAGE BRUSH PEARL EXL,REAR SPLASHGUARDS,CARGO LINER,CARGO COVER,CARGO TRAY,CARGO ORG.,OEM WHEEL LOCKS, Delphi XM Radio,Nuvi 350,660 ,Garmin 2620,VIN 522044 |
#19 (permalink) |
Knocking noise is pretty loud but goes away when it warms up, 3-4 minutes. I'll rev it up tomorrow and see if it disappears at higher RPM.
It's frustrating not knowing who can tell the difference between Valve lash adjustment and Timing belt, etc. I certainly don't want to replace the timing belt 20K too soon unless I know that's what it is. Thanks. By the way, what is VCM? Alexander |
#22 (permalink) |
I am having this exact same issue as you are all describing! '06 Pilot with a 86,000 miles.
I am going to change the timing belt tensioner, oil (back to 5W20 instead of the 5W30 I just used) and I'll try the sea foam. As a side note, before I bought the car, the PO had the valve adjustment done because it was showing the cylinder misfire codes. |
#25 (permalink) |
I'm familar with knocking noises coming from engines with hydraulic tensioners and cam CHAINS, but a belt? In the tensioner theory, is the knocking noise from the un-tensioned belt hitting something? Do our engines have hydraulic tensioners?
- Mark |
#26 (permalink) | |
Yes these motors have an oil loaded tensioner device. See here More Information for GATES TCKWP329 The adjuster is the piston loaded barrel looking thing. The noise comes not from the loose belt or from the pulley but rather from the loose tension adjuster. What happens is the oil in the adjuster weakens, The piston forces the pulley onto the belt but cannot hold so you end up with a metal to metal knocking noise with the the tensioner pulley. I've heard this noise first hand on an Isuzu which uses almost an identical setup. It sounds like a rod knock. An isolated, low end metal to metal knock. The telltale is that as you rev the motor eventually you hit a rpm at which the rotation of the belt forces the piston all the in and the noise stops completely. |
#30 (permalink) |
I had the same noise happening some days and not others, sometimes very loud or sometimes quieter. I took it to Honda a few times, they said nothing wrong with engine so I ran with it that way for about 15k miles (75k to 90k). At 90k I decided to do timing belt replacement. They told me the tensioner needed replacement as it allowed too much movement and a carbon cleaning. A grand later the car is quiet as a nun. I don't know if it was the belt, the water pump or the tensioner, but with all three replaced its gone and the car has balls again like when it was new.
