Changing tire on a Pilot with Side Steps - Honda Pilot - Honda Pilot Forums
Old 02-02-2012, 03:29 PM   #1 (permalink)
Default Changing tire on a Pilot with Side Steps
hello, this might be a dumb question but here goes.
i have an 06 pilot with oem side steps that i installed.
after installing them i wondered how a place like America's Tire would lift the Pilot to install new tires?
it seems like the lift they use would try to lift the Pilot using the side step brackets.
jason330i is offline   Reply With Quote
Old 02-02-2012, 04:00 PM   #2 (permalink)
They would life on the car's sills just like they would if the car did not have steps on.
Old 02-02-2012, 04:12 PM   #3 (permalink)
hi rocky,
so you don't think the brackets would get in the way?
they just seem to protrude so far down...
see attached pic.
edit: i should clarify that america's tire has one of those lifts that you drive over and two long "forks" lift your vehicle up. it's not like costo, where they have 4 adjustable points that lift your vehicle up.
Old 02-02-2012, 07:08 PM   #4 (permalink)
onu2002's Avatar
Ask 'em. And if they can't, go somewhere else.
Tom
2003 Honda Pilot EX
2004 Honda S2000
2006 Hyundai Sonata GLS
Old 02-02-2012, 09:00 PM   #5 (permalink)
Most places lift from the frame rather than those flimsy sheet metal jack points that you use to change a flat.
Old 02-03-2012, 10:37 AM   #6 (permalink)
Send a message via Yahoo to malmon
When I had tires replaced at America's tires, they used floor jacks to lift our 05 pilot with side steps. I saw them used their lift on other vehicles, but not on the pilot, maybe because of the side steps.
2005 EXL-NAV Billet Silver Metallic
malmon is offline   Reply With Quote
Old 02-03-2012, 10:47 AM   #7 (permalink)
RSQ Pilot's Avatar
Garage
It all depends upon the service center's choice....
Honda service and Discount tire both have used lifts for my Pilot with running boards. I have had several SUVs and trucks with running boards or side steps they have all gone up on lifts without any issues.
Old 02-03-2012, 11:49 AM   #8 (permalink)
94eg!'s Avatar
^This. They should see the difference and jack the car accordingly. If your worried about it, just keep an eye on them. Request they use floor jacks if they try putting it on a frame lift.
Old 02-03-2012, 01:43 PM   #9 (permalink)
exploreco97's Avatar
Same here too. I bought my tires at Discount Tire also, and they have only used floor jacks on my Piolot. They use the lifts on my wife's Camry though.
2007 Pilot EX-L 4x4 Taffeta White - 59,000
OEM Running Boards, 50 % Tint, Michelin LTX MS2, XM Radio, Weather Tech Digi Floor Liners
2004 Toyota Camry LE - Desert Sand Mica -87,000
35% Tint, XM Radio
exploreco97 is offline   Reply With Quote
Old 02-03-2012, 04:14 PM   #10 (permalink)
cool. thanks for the info.
Old 02-03-2012, 09:26 PM   #11 (permalink)
iggibar's Avatar
Most lifts have adjustable end arms to position at the closest frame location. I know Conrads and Costco has them.
2011 Honda Pilot EX-4WD. [bought]
2011 Honda Accord Crosstour EXL-4WD. [leased]
2009 Ford Focus SE. [bought]
iggibar is offline   Reply With Quote
