Two summers ago my AC quit. Its gas had leaked out. I have the full Honda Care extended warranty, so I took the 2006 Pilot to a dealer for repair under policy. Dealer claimed he could not locate the leak. Policy does not cover cost of recharge without repair, so I was stuck recharge cost. Dealer installed a dye for leak tracing in case problem recurs. Last summer during extremely hot spell, AC started intermittently blowing hot air then only hot air. When ambient temp is lower, AC works fine. Classic case of leak of some but not all gas. Need to take Pilot back for repair. Fear: Dealer will again tell me he cannot find leak and charge me for AC recharge. Question: How long will the dye remain seeable by technician with proper light? Has too much time passed such that dye traces disappeared? Note the engine (hence AC junction points) has not been washed. In other words, how permanent are the dye traces at the leak point?
The dye should be visable. Before you go back to the dealer, maybe pop the hood and take a look.
Maybe a good local AC shop will do you a favor and take a quick look around.
All in good will. If the system has a leak, I would go back to Honda to cover the previous filling.
If you want to take a look yourself, I've seen those kits with both the light and glasses sold in auto parts stores.
A large leak will be plainly visible with the naked eye in daylight. Since yours is small, I'm guessing you would definitely need glasses & UV light, and probably check it in the dark. You can get all that stuff at Autozone for a few $$. Good luck.
