Rear Blower Transistor in Canada - Honda Pilot - Honda Pilot Forums
Old 01-05-2012, 10:05 PM   #1 (permalink)
Default Rear Blower Transistor in Canada
Does anyone know of a company that will ship a OEM rear blower transistor to Canada besides a Honda Dealership?
darcand is offline   Reply With Quote
Old 01-05-2012, 10:53 PM   #2 (permalink)
Ebay or just fix yours.
Rear blower Transistor Fix
What's so bad about dealers?
Old 01-05-2012, 11:14 PM   #3 (permalink)
roarkrd's Avatar
My guess would be the dealer wants one VERY shiny penny for the rear blower transistor.
Old 01-05-2012, 11:53 PM   #4 (permalink)
Thanks carguy, I cant seem to find any on Ebay that will ship to Canada and I am not the most technical person when it comes to DIY electrical. Nothing against dealerships, I always assumed their prices were more expensive.
Old 01-06-2012, 12:27 AM   #5 (permalink)
roarkrd's Avatar
Replacing the thermal cut off in the rear blower transistor is probably one of the easiest DIYs. I did it with no experience and it only took a couple of minutes.
Old 01-18-2012, 05:27 PM   #6 (permalink)
Replacing the thermal cutoff on your rear fan resistor is not hard to do, provided you have good working knowledge of electronics. You could however fix it this way. Buy the .44 thermal cutoff (inline fuse) from Mouser Electronics, part number 667-EYP-2BN110 in fact buy 2-3 because they are so cheap freight will be more expensive. Also buy heat sink compound needed to keep the new thermal cutoff from prematurely overheating. Mouser part number 526-NTE303. .62 cents. Just like a processor on a computer board is bathed in white thermal heatsink compound, the above thermal cutoff fuse likes to be coated in the same stuff.
Then download Honda Service Bulletin 03-048 and take to a qualified mechanic. The whole repair should take 30 minutes of labor, including time to soder the new heat sink onto the old resistor with the mouser parts.
Total cost is $10 parts, fixed better than new, plus 1/2 hour labor. Cheaper than new Hona Part of $100 bucks. The new thermal cutoff has a higher heat rating of the old.
If replacing with new honda part... you can do this yourself. The old resistor comes out and the new resistor plugs back in. Take time to put the side panel back on to get it to fully snap back into place. Clean the wire air intake filter while you have the panel off! This is why the resistor failed in the first place. It simply got to hot from lack of air flow.
EVERYONE should pull the floor panel off and clean the filter yearly to keep the air flowing and the resistor will stay cool. Preventative is always the best defense!
wirth315 is offline   Reply With Quote
Old 01-19-2012, 09:43 AM   #7 (permalink)
Good idea, I think I'll add that to my spring cleaning checklist along with lubricating the caliper sliders.
2006 Honda Pilot EX-L
Ottawa Ontario, Canada
mikemcm is offline   Reply With Quote
