2004 transmission - Honda Pilot - Honda Pilot Forums
Old 01-05-2012, 07:08 PM   #1 (permalink)
Default 2004 transmission
My transmission on my 2004 EX surges gently around 45 to 50 in D4. What could be causing this?
hp2004 is offline   Reply With Quote
Old 01-05-2012, 07:40 PM   #2 (permalink)
You dont have a gear selector d4. Do you mean while in fourth gear with the selector in drive?
osudelt69 is offline   Reply With Quote
Old 01-06-2012, 11:43 AM   #3 (permalink)
Yes in "D", sorry.
Old 01-06-2012, 12:55 PM   #4 (permalink)
dustino8's Avatar
Does it occur more often under very light acceleration? If so, it could be the EGR valve needs cleaning/replacement. Relatively common on the older Pilots. Sometimes it will trigger the VTM and CEL lights, but not always.
2007 Toyota Tundra
Old 01-06-2012, 03:14 PM   #5 (permalink)
I am guessing it is the 4th gear pressure switch and/or the torque converter lock up clutch.
The switch is easy, and the clutch is usually a new transmission.
There is some thought that as the switch wears out/fails, it is what is causing the clutch to fail.
At those speeds you are in 5th gear and the clutch is cycling in and out of lock-up.
But it could be the EGR also, the feeling is about the same.
EGR usually trips a Check Engine and even a VTM warning light.
Trans usually does not till it is bad enough to trip the flashing "D".
Old 01-07-2012, 09:08 AM   #6 (permalink)
I do get the flashing "D" light occassionaly.
Old 01-07-2012, 10:19 AM   #7 (permalink)
You should have the dealer check your Pilot. Flashing D is NOT normal and they need to check fluid level and codes ASAP especially since you have a shifting issue.
Old 01-07-2012, 10:32 AM   #8 (permalink)
It shifts fine, just have that slight vibration from 45 to 50 mph. I have a good local mechanic in Pensacola, Honcare, which does great work.
Old 01-07-2012, 11:43 AM   #9 (permalink)
Have him change the 4th gear pressure switch, change the fluid, and hope it gets much better.
Try not to drive at the speed where it happens, as a chattering clutch is a destructive process.
Old 01-07-2012, 12:57 PM   #10 (permalink)
Nay since you changed your switches a while ago, how has it been.
I'm thinking about doing third and fourth.
Old 01-07-2012, 01:12 PM   #11 (permalink)
It is better but not perfect.
My guess is with the high gearing and low engine speeds of the 5th gear, a bad switch engages 5th a little too early putting more then normal strain on the lockup clutch.
Chattering clutches of any kind self destruct very quickly.
I probably caught it a little late, and the clutch is a bit worn.
There was also the person (I forget who) that cleaned a filter on a valve and had some good luck.
I have not gone there yet.
Old 01-07-2012, 02:17 PM   #12 (permalink)
Any idea on est. cost for the repair of the pressure switch?
Old 01-07-2012, 02:35 PM   #13 (permalink)
tangotango99's Avatar
they must be replaced not repaired, there is a post of DIY
Old 01-07-2012, 04:34 PM   #14 (permalink)
roarkrd's Avatar
I had my fourth gear pressure switch replaced about 6 months ago and it cost about $270 ($160 of that was labor alone. The hourly labor rate was $105!). I suggest changing it yourself if you have the time and tools required.
Old 01-07-2012, 04:37 PM   #15 (permalink)
Was that @ certified dealer or your local mechanic?
