crossbars question - bars moving back and forth - Honda Pilot - Honda Pilot Forums
Old 01-02-2012, 01:24 PM   #1 (permalink)
Default crossbars question - bars moving back and forth
Hi Guys,
I bought some ebay oem style crossbars to attach ski carriers when hitting up the mountains.
the bars are like these:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
They are fitting pretty nicely, except I cannot make them stationary - I can easily move them back and forth. Well, not all the way back and forth since towards the rear the width decreases so at some point they become tight, but this cannot be right. i would think when the top bolts are tightened the bars should not move anymore...
I have sent question to the seller, but i was wondering what tightens the OEM bars? I may make a trip to the dealer to find out more info, but if anyone can give me a clue i would appreciate it.
islavov is offline   Reply With Quote
Old 01-03-2012, 11:38 PM   #2 (permalink)
got the manual from the seller (attached), but it does not help me.
I had done exactly the same install...
Do the OEM bars move back and forth? can someone confirm?
Old 01-04-2012, 01:30 AM   #3 (permalink)
94eg!'s Avatar
Sorry but I cannot open that file. Here is the Honda manual:
http://www.bernardiparts.com/Images/...y_AII30491.pdf
When you tighten the bolts in step 6, the cross bars are supposed to clamp down onto the existing side rails. If yours do not do that, you may need to figure out a way to shim them so they do clamp down. If that's not for you, think about sending them back.
Sorry for your trouble. Seemed simple enough for someone to easily replicate.
Old 01-07-2012, 11:35 PM   #4 (permalink)
Thanks for reply!
I had the same manual.
well, mine dont clamp, they are not that loose either.
I guess, you get what you pay for. i may have to shim them somehow.
