How do I remove the hazard light switch on my 2006 Pilot (without navigation)? The bulb needs to be replaced. I have not found this specific discussion on this forum. Am I missing something?
![]() Note that I have read the discussions elsewhere in this forum on how to remove the climate control face to replace the nine bulbs in it. Must I get that part out in order to be able to move on to the hazard switch? Or can I gain access to the hazard light switch without proceeding through the climate control bulb section? Thank you. |
Remove the entire gray section of dash starting with removal of the blank switch location on the other side. Process is described in several threads in the audio section
Thank you. By "entire gray area" am I correct that you mean the part that surrounds the radio, outside of the black surround that holds the hazard switch?
How easy is it to screw up and snap/break these surrounds or their projections that hold the metal clips? Everything appears so fragile. I looked for some threads under audio and radio and found a couple. Would you be kind enough to point me to the most relevant threads? Thanks again. |
