Check Fuel Cap Message - Honda Pilot - Honda Pilot Forums
Old 12-19-2011, 10:18 AM   #1 (permalink)
Question Check Fuel Cap Message
What can I check to see what may be causing this message "Check Fuel Cap"? I have removed the fuel cap and reinstalled it. It appears to be on correctly?
bradabarker is offline   Reply With Quote
Old 12-19-2011, 11:23 AM   #2 (permalink)
It takes some time for the message to go away, about 3-5 days or so. If it doesn't reset on its own, maybe it's time for a new gas cap.
Old 12-29-2011, 06:25 PM   #3 (permalink)
not aware of a warning light specific to the fuel cap but my engine light came on 2 months back and the codes pointed to the evaporative fuel system. It turned out to be my gas cap was loose I've noticed after a few refills. Replaced and all is fine now- make sure not to overtighten/turn the cap- 3 clicks is sufficient and will make it last a long time.
2004 Pilot EXL-RES, 85K miles.
