Front dome light issue - Honda Pilot - Honda Pilot Forums
Old 12-13-2011, 07:50 AM   #1 (permalink)
Default Front dome light issue
My front dome lights won't turn on when the doors open and yes the switch is on! When I push the drivers side one it will turn on and off! I thought I had a burnt out passenger side one but when I opened the lens, it flickered and then I took it out and out it back in and it worked fine and when I opened the door the passenger side came on, but not the drivers side. That only lasted a couple of times and now I'm right back where I started. I did a search for this problem, but couldn't find anything! Can someone point me in the right direction? Thanks!
fishoutofwate91 is offline   Reply With Quote
Old 12-13-2011, 08:03 AM   #2 (permalink)
Have you checked the switch on the door jam to make sure it isn't sticking, corroded, etc?
whozleft is offline   Reply With Quote
Old 12-13-2011, 08:30 AM   #3 (permalink)
If you use the word dome in the search function this threw comes up just a few threads after yours
Dome light problem
