I was wondering if anyone else has had this error code PO301 engine misfire cylinder 1. I have 68k miles and it runs normal no noise or loss of power.
Sounds like it could be a number of things - spark plug, coil, valves etc. Just wondering if there is a common problem or if there are some things that rarely break (coil). Also if I bring it in and they suggest valve adj should I get water pump and belts or is it too early. Thanks |
Maint Master
If you get the random misfire P0300 and P0301-P0306 codes with 2006-2008 VCM
check this link: Multiple Cylinder Misfire Codes
76 CB360, 78 CB750, 1975 HONDA CIVIC WAGON CVCC, 1982 Honda Civic , 2008 Honda Pilot Kenwood DDX-812 with KNA-G510 Nav, Infinity 6022si door speakers, MTX 10" Subwoofer upgrade, Alpine SBS-05DC center with JPA460 power amp in 3 channel bridged mode. Rear camera and DTV converter box with second and third row monitor screens. Wired and wireless headphone adapters.
Great TSB that helps a lot! I will see if the dealer will do the work but I think I am past warranty at 68k. At the very least I can take it to a shop and they will know where to start.
Thanks |
