03-08 Problems - Honda Pilot - Honda Pilot Forums
View Poll Results: Areas of problem you've faced with your Pilot
Engine 3 16.67%
Transmission 4 22.22%
Electrical 2 11.11%
Suspension 7 38.89%
Wheels/Brakes 4 22.22%
Audio 2 11.11%
Heating/Cooling 7 38.89%
Multiple Choice Poll. Voters: 18. You may not vote on this poll
Old 12-11-2011, 11:07 AM   #1 (permalink)
Default 03-08 Problems
I wanted to get a general idea of all the problems that people have faced and what areas they fall into. Sort of a replacement list with millage attached. This should give people an idea what to keep an eye on and what where some of the success stories attached or heart breakers.
On my pilot, 07' LX 4WD 61k miles (owned since 43k)
-Front Sway Bar Links @ 43k
-Front and Rear Brake Pads and Rotors @ 55k
-Rear Main Seal @ 60k <--- Goodwilled by Honda
-Oil Pan gasket (Thought to be the leak that turned out to be the rear mainseal) @60k
That's it for me. I've been very happy
Acura2g is offline   Reply With Quote
Old 12-12-2011, 10:44 PM   #2 (permalink)
I replaced front link stabilizers at 106920 miles and I also changes the tie rod end dust boots and lower ball joint dust caps.
at 11000 the rear main seal started leaking and was fixed.
that is all I have had to fix besides regular maintenance items(belts,filters,fluids and brakes).
kody53 is offline   Reply With Quote
Old 04-12-2012, 12:27 AM   #3 (permalink)
2006 now 92K miles. Radiator leaked when new,noisy serpentine belt and pulleys,coolant smell,interior leaks,radiator fan relay,rear heat controls,XM radio fail,leather seats cracked....
imaduner is offline   Reply With Quote
