No Seat Heat!!! - Honda Pilot - Honda Pilot Forums
Old 12-10-2011, 08:37 AM   #1 (permalink)
Default No Seat Heat!!!
My 03 Pilot EX-L now does not have seat heat. Any suggestions? Is it difficult to get to the heater pad to replace?
mgreig0230 is offline   Reply With Quote
Old 12-11-2011, 10:56 AM   #2 (permalink)
Hi, If the switch lights up, I would check the power at the connection to the seat and do a continuity check on the seat pad. I have never had to replace a pad but it can't be that bad unless of course you are doing it outside.
2005 Honda Pilot EXL
2003 GMC Envoy XL
2002 Toyota Highlander
1993 Mercedes 600SL
I am lost when there is no grease under my finger nails.
playstrings is offline   Reply With Quote
Old 12-11-2011, 10:57 AM   #3 (permalink)
Yesterday I was playing with the infamous hood switch outside, rather chilly at 30deg F.
2003 GMC Envoy XL
1993 Mercedes 600SL
Old 12-11-2011, 11:11 AM   #4 (permalink)
The heater coil in the seat is a very small gauge wire and over time they can break.
I had this happen on my 99 TL. I ripped apart the seat to get to the coil and found a break in it that had melted the seat cushion and almost started a fire.
I soldered it back together and wrapped it with electrical tape and it worked like a charm after that.
Acura2g is offline   Reply With Quote
