Need help code u0122 VSA etc HID - Honda Pilot - Honda Pilot Forums
Old 12-01-2011, 03:25 PM   #1 (permalink)
Default Need help code u0122 VSA etc HID
Ok im getting a code u0122. To give you back ground my pilot is an 06 exL that I bought about 8 months ago. The previous owner had an HID kit installed on the low beams only. About 2 weeks ago one of the HID bulbs went out and I pulled the bulb and have been trying to find a replacement but no luck.
The other day a buddy of mine was looking under the hood trying to see what kind of conversion kit was on it and noticed the running light bulbs were unplugged and so was one of the radiator fans. We assume the bulbs were unplugged when the HID conversion was done and had no idea why the fan was plugged up. He plugged all 3 up and all 3 worked with no problme when I restarted the car BUT the Brake light, VBS and ABS lights all came on. My buddy cleared all of the codes and on restart they immediately came back on. We unplugged all 3 again cleared the codes and restarted to see if that was the problem but all 3 lights came immediately on. ANY IDEAS??? We checked all the fuses and they were good.
oconee1985 is offline   Reply With Quote
Old 12-16-2011, 07:55 AM   #2 (permalink)
UPDATE:
We unwired the HID kits and restored the factory headlights. Speaking of which that took some time because we finally figured out the plug ends about a foot from the bulb is square but the bulb plug is oval and for some reason Honda has a connector that goes between the two to convert it to oval. Anyways everything is working fine with the headlights but Im still getting the error message and the lights coming on. Anyone have any ideas I would appreciate it.
