Hi everyone,
I just went out and bought me a ( new to me ) used 05 Pilot. It has high miles but seems to be well serviced. The previous owner took the Pilot into the dealer because the SRS light was on in the dash. The dealer reset the airbag sensors claiming the front left reset but came back on. The right front reset fine but the dealer says both front sensors should be replaced. I was thinking maybe the front left might have a corroded connection. I would like to get up under the car to check this but have no idea as to what to look for. Can anyone give me an idea as to how to find those sensors to see if in fact maybe a little tug and clean will fix it? |
I don't know much about those sensors. Most air bag wiring is wrapped with yellow loom or tape. Here is a link that might come in handy.
Need to Reset your SRS Light...DIY Instructions - Acura MDX Forum : Acura MDX SUV Forums |
I finally found them ( front ones at least). If you look straight down in between the battery and headlight you can see the Yellow Wiring attaching to the sensor. I wiggled it and it seems pretty tight so was hoping to wiggle to a better connection,,, but no go. So it's in the shop getting a new sensor installed.
