Recently my Pilot's idle has started oscillating (high/low) when engine is at idle. Any leads as to what might be causing this?. Just lost my job and want to tackle this myself if I can. Vehicle has always been dealer maintained but just can't afford to bring it to the shop at this time. Thanks in advance for any suggestions...
Is the AC system off? AC cycling can cause variable idle.
First place to look is the IAC, Idle Air Control. It may well be dirty. Carb cleaner such as gum out from the local auto parts store would be the solution.
I got in there & sprayed carb cleaner throughout the throttle valve body with engine running & did nothing to alter the erratic idle. I then proceeded to check all connections to several components attached to the throttle valve body. I systematically disconnected each to check for corrosion but found none. Somehow in doing so, my problem has disappeared! Not sure if this will permanently correct the problem but for now I am happy that with a little time, effort & $0 dollars it has gone away. Thanks for the advice!
Thanks for the follow up, it appears there may have been a vacuum leak that you tidied up. Taking the time to properly clean the throttle body is just good maintenance. Just spraying cleaner in there does little , you need to clean it up using a brush and rag so the butterfly will seat cleanly. FWIW ...
2005 Honda Pilot EXL 2003 GMC Envoy XL 2002 Toyota Highlander 1993 Mercedes 600SL I am lost when there is no grease under my finger nails. |
