Changing Battery in 2004 Pilot - Honda Pilot - Honda Pilot Forums
Old 09-30-2011, 10:49 PM   #1 (permalink)
Smile Changing Battery in 2004 Pilot
Are there any issues I have to deal with after disconnecting the old battery (for about 10 minutes) and installing a new one? The Owner's Manual mentions that the power window system needs to be reset, but nothing is said about the audio system password. Is it really that simple???
From one very satisfied Honda owner...
Roger
Gliderpilot is offline   Reply With Quote
Old 09-30-2011, 11:05 PM   #2 (permalink)
You'll need the passcode for the radio if the battery is disconnected along with the window reset.
Old 09-30-2011, 11:50 PM   #3 (permalink)
Send a message via Yahoo to cali510
I changed my battery not long ago and only had to have the radio password.
cali510 is offline   Reply With Quote
Old 10-01-2011, 12:04 AM   #4 (permalink)
So you mean to say you didn't have to reprogram the driver's side window for the auto up/down feature?
Old 10-01-2011, 01:30 AM   #5 (permalink)
94eg!'s Avatar
If your auto-up/down function doesn't work after the swap, there is something special you have to do. Something like hold the button at max to go down for like 5 seconds. Then hold it at max to go up for 5 seconds. This will reactivate the auto-up/down function.
Old 10-01-2011, 07:00 AM   #6 (permalink)
xGS
xGS's Avatar
You will have to enter the anti-theft code, reset the time and reprogram the radio station presets.
http://www.piloteers.org/forums/atta...al-page102.jpg
http://www.piloteers.org/forums/atta...al-page103.jpg
Old 10-01-2011, 02:54 PM   #7 (permalink)
Thank you Gentlemen!
Old 10-02-2011, 02:42 AM   #8 (permalink)
tangotango99's Avatar
After replacing my battery, the drivers side window did not require reprogramming.
Old 10-02-2011, 12:49 PM   #9 (permalink)
roarkrd's Avatar
I don't think it's unusual, I never had to reprogram the CRVs when I would disconnect the battery; even if it was for long periods of time.
Old 10-02-2011, 09:13 PM   #10 (permalink)
nope didnt have to reprogram the driver side window,only had to have the passcode for the radio.
Old 10-02-2011, 11:49 PM   #11 (permalink)
nobby's Avatar
I had my battery disconnected for some welding and another time I had it out for replacement.
All I had to reset was the radio stations.
That's it.
"Bob's Your Uncle!!"
2006 Pilot LX
2008 VW Golf
1983 MB 280SL
nobby is offline   Reply With Quote
Old 10-06-2011, 12:27 PM   #12 (permalink)
To avoid all this, why don't you get one of those battery savers, a 9v battery that plugs into the cigarette lighter and keeps the accessories powered for the short time it takes to change a battery.
I changed my battery and only had to enter the radio password, and reset the stations. The window was fine.
2005 Pilot EXL
2006 Accord EX I4
2010 Mariner V6
normkol is offline   Reply With Quote
Old 10-09-2011, 11:24 AM   #13 (permalink)
Just need the radio code when i unhooked my battery on 2004
osudelt69 is offline   Reply With Quote
Old 10-09-2011, 08:00 PM   #14 (permalink)
Those won't easily work since the plug goes dead when the key is off. Do NOT try to cheat and use one with the key on. Bad things can happen if you lose power with the key on.
