Outside temp sensor? - Honda Pilot - Honda Pilot Forums
Old 09-25-2011, 12:24 AM   #1 (permalink)
Default Outside temp sensor?
Is it possible to add this to a 08 LX? What would I need to make this work? I cant even find it on the fiche. I can see the shaddow of it on the instrument cluster.
2008 Honda Pilot LX 4WD
qwikz74 is offline   Reply With Quote
Old 09-25-2011, 10:12 PM   #2 (permalink)
Send a message via AIM to max6spd
My 05 has it. Just hit the trip meter. Trip A, Trip B, Temp
2010 Azurite Blue Pearl Subaru Legacy GT - Mine
2005 Billet Silver Metallic Honda Pilot EX-L - Hers
max6spd is offline   Reply With Quote
Old 09-25-2011, 11:14 PM   #3 (permalink)
OP has an LX, probably need to install the temp sensor, which wasn't available on the LX trim level.
Old 09-26-2011, 04:41 AM   #4 (permalink)
Gotcha
Old 09-26-2011, 05:18 PM   #5 (permalink)
So is that all there is too it? Order the sensor and plug it in?
Does Honda leave the harness taped up somewhere?
Old 09-27-2011, 12:45 PM   #6 (permalink)
krazykarguy's Avatar
If the LX wire harness has the plug-in for the outside temperature sensor, it will be located behind the center lower portion of the grille.
However, I doubt very highly that you can just plug in a sensor and the display starts displaying the outside temperature. This part of the display is a multi-use display, and if cycling the different displays (odo A, odo B, overall odo, Oil life %) does not show the "temperature" display, I doubt that it's part of the circuitry for your Pilot.
Old 10-15-2011, 12:25 AM   #7 (permalink)
i was able to locate the sensor but i dont know how to activate it. it must be just a fuse that is needed.i also have a 2011 lx 4wd honda piot
alfie is offline   Reply With Quote
