My wife was driving on a highway doing about 55mph when she said it slipped out of gear and would not accelerate. She was able to pull over and call me. She said the transmission was in D, but when she pressed the gas it was as if the car was in neutral. I asked her if she could shift into 2 or 1, and she said she physically could not. She could shift into reverse, but it still wouldn't move. Eventually she was able to get it to limp off the main highway. She said she couldn't go any faster than 15 mph.
When I got there I saw a decent sized puddle of what appeared to be foamy tranny fluid on the ground, but it wasn't under the transmission - it was dripping from the front right of the vehicle. It was coming from the engine coolant overflow bottle. I had it towed to a local tranny shop, and they told me the transmission intercooler had a crack in it somewhere, and it leaked into the radiator, causing trans fluid and antifreeze to mix. There is trans fluid in the cooling system, and antifreeze in the transmission. They are replacing the radiator and performing 4 flush and fills of the transmission and the engine. They say they can get the car back up and running again, but because of the ethylene glycol getting into the trans, it will attack the clutch plates and eventually the transmission will fail. my questions to you: Any of you heard of this happening? The guy at the shop said it's common, but this is the first Honda he's seen with this problem. What are the chances of my transmission failing quickly? I'm worried it will start slipping and I'll have to pay for a full rebuild (which is not cheap!). Any insight on this? I'm thinking about trading it in and letting it be the dealer's problem! I've been thinking about getting into an 08-10 Pilot for a while now anyways
![]() 2005 EX-L Billet Silver Metallic | 2007 EX-L Billet Silver Metallic |
Yes there are threads with this reported. Sorry to say but you now hAve a high chance of tranny failure.
@rocky
i searched piloteers for threads on this but i didn't come up with anything. do you have any links you can share? thanks!
Using radiator in the search function, and not going back too far in time, brought up many threads. Have selected these for you.
Help!!Transmission Issue Help!!! Help! Possible Transmission Problem Might be worth posting in those threads requesting a follow up from the OPs
Ours was caught immediately and not driven to the point of slippage. Wife noticed the puddle start as she was exiting the Pilot at a store. She then drove to the Honda dealer which was 1/4 mile away. The fluids were immediatley flushed multiple times. Best case possible. Haven't had a problem with the tranny since. |
It's not necessarily a "bad design", as just about every automatic transmission-equipped car I've worked on in the last 15 years has utilized a portion of the radiator to cool the transmission. It's an industry standard practice.
I would say that this type of failure can be chalked up to not enough failure testing 10 years ago when the Pilot was initially being torture tested. Nissan has had a bunch of identical failures with the Xterra. |
If concerned, I wonder if a super-aggressive ATF changing schedule for 30,000 miles after the incident might help avoid a failure, or is it too late the moment the friction material is exposed?
#11 (permalink) | |
#13 (permalink) | |
#14 (permalink) | |
The information contained here; Automotive Questions and Answers - while getting a bit 3rd hand, seems pertinent. It sounds like once you've got some antifreeze in the system, you're potentially in real trouble. Of course, the friction materials Honda use in their rather unusual transmissions are perhaps not subject to this sort of degradation, who knows. I wouldn't bank on that though.
In case that link breaks, I'll post the meat of it here; Quote:
Just a thought, anyway.
#15 (permalink) | |
2008 Honda Pilot LX 4WD |
