Transmission oil Pan: Drop it or not for regular maintenance - Honda Pilot - Honda Pilot Forums
Old 09-14-2011, 07:09 AM   #1 (permalink)
Default Transmission oil Pan: Drop it or not for regular maintenance
I have 2008 pilot with 70K on it. I have changed automatic transmission fluid as recommended. I had an Old Volvo 240 earlier and it was a common opinion that transmission pan should be dropped to clean it for all the gunk.
What are the options for Pilot? Is it a common maintenance item.
Another question is if there is a transmission fluid filter which needs maintenance.
Regards,
vclifford is offline   Reply With Quote
Old 09-14-2011, 10:06 AM   #2 (permalink)
samc's Avatar
Not really necessary on such a new vehicle. But I was also told that every few years you should drop it to clean out the gunk and what not.
I believe the filter is not easily accessible and so it's not a service item.
