Keyless entry half works! - Honda Pilot - Honda Pilot Forums
Old 09-12-2011, 05:14 PM   #1 (permalink)
Question Keyless entry half works!
Hi, New-be here.
2003 Pilot EX-L, I have owned it since new, 275,000 KM's on it now, 2 transmission overhauls.
For some reason the right front and right rear lock in the doors do not work with the keyless remotes, and the toggle on the drivers main switch...
Any ideas?
mgreig0230 is offline   Reply With Quote
Old 09-12-2011, 06:18 PM   #2 (permalink)
STFF (search the FABUOLOUS forum)
2003PilotEx is offline   Reply With Quote
Old 09-12-2011, 06:26 PM   #3 (permalink)
Thank you....appreciated
Old 09-12-2011, 07:37 PM   #4 (permalink)
Default Keyless entry ,,...
Hi 2003PilotEX
What is this exactly....(search the FABUOLOUS forum)
Old 09-12-2011, 10:17 PM   #5 (permalink)
Originally Posted by mgreig0230 View Post
Hi 2003PilotEX
Click on the "Search This Form" green tab that is on top right corner above the threads. Enter the words "keyless entry" and many threads will come up describing possible solution. You will probably need to replace the Lock Actuator(s) .
good luck.
Old 09-12-2011, 10:21 PM   #6 (permalink)
theirishscion's Avatar
If they both failed at exactly the same time, I'd look closely at the switch/connector in the drivers door. I don't know if the central locking relays through that point, but I wouldn't be surprised.
"The HDMI Wagon"
Old 09-15-2011, 04:35 PM   #7 (permalink)
I took the door switches off and inspecyed...(my wife is a heavy coffee drinker and a smoker so the door window is always open)...I asumed the door switch panel was fried from spillage, or weather...it looks fine, and the connectors are OK as well. I will dig deeper....
Thank you guys, I appreciate the tips....stay tuned.
Old 09-15-2011, 10:40 PM   #8 (permalink)
on Amazon.com search for Honda Pilot Lock Actuator. You will need to replace for each door that is not locking. Each is about $30. You will need to be very careful in removing and insatlling. I had a hard time putting back in the correct position and ended up breaking a piece of plastic the holds the rod that connects the inside handle to the actuater.
The moral of the story, before you it take it out make you know how it's situated..
