I got this code from Autozone for my 2006 Honda Pilot after I got a Check Engine Light and the blinking D. My engine performance is really bad especially I get shuddering alot especially in the first and second gear. What do I need to do? I did changed the transmission oil at 30,000 miles and a few days ago after I noticed bad performance on my transmission.
Is my transmission toast and need to replace with a new one? |
Here is what I got from the web when I googled for more info about this code for Honda:
P0746 - Clutch Pressure Control Solenoid Valve A Stuck Off Symptoms: - Engine Light ON (or Service Engine Soon Warning Light) - Transmission shift shock Possible causes: - Faulty line pressure solenoid valve - Line pressure solenoid valve harness or connectors - Line pressure solenoid valve circuit is open or shorted - Low transmission fluid level - Dirty transmission fluid Tech notes: When the a transmission solenoid is stuck off, in most cases the problem is not the electrical part of the solenoid; the problem is foreign material obstructing the mechanical function of the solenoid or the flow of the fluid through the transmission valve body. If the transmission fluid is very dirty, it is recommend changing the transmission fluid and if possible removing the transmission pan for further diagnosis. Excessive debris or metal particles on the transmission pan could be an indication that there is a transmission mechanical failure and that the transmission will need to be rebuilt or replaced. When is the code detected? The gear required by the Engine Control Module (ECM) does not match the actual gear when driving P0746 HONDA Description: The line pressure solenoid valve regulates the oil pump discharge pressure to suit the driving condition in response to a signal sent from the Transmission Control Module (TCM). |
What to do next? Please let me know. Maybe I need to do 2X drain and fill transmission oil to see whether it helps or not. Call the Honda dealer tech to see what they say about this code. Call HOA for a possible new transmission replacement for a good will.
Since I got code from Autozone, I wonder do I need to visit Honda dealer for $100 fee to detect code? |
A 2006 with 44k? Bring it to Honda for diagnosis and ask for full reimbursement. Since you bought it new, they will likely cover it under goodwill as long as you can show that the tranny fluid was changed at the intervals required. The fee will be covered if any work is done.
The actual miles on my car is 43,502 miles. The dealer that I bought from told me that I have to pay $100 to do diagnostic through computer. I never bring to the dealer for changing oil because I did it by myself. I changed transmission oil at 30,000 miles and at a couple days ago. I bought 1995 Honda Accord V6 as a brand new and done all oil change by myself and it is still running well at 145,000 miles. This is really bad.
The reason I want to do it by myself is because I don't want to wait for an hour for an oil change. |
I think that I changed around 3 years time frame. I think I will pay $100 for the deal to do it; then ask Honda to pay for it. |
Guess what! Honda Dealer will give me a new transmission with 12 months/ 12 thousands mile warranty; but I have to pay $532. Oh well, that is ok I am happy for it because I am out of warranty on bumper to bumper or powertrain. Any way, I am happy that they will replace my Honda Pilot.
