2006 pilot//Vibration on my steering wheel and gas padal - Honda Pilot - Honda Pilot Forums
Old 08-26-2011, 07:27 PM   #1 (permalink)
jurena0915's Avatar
Exclamation 2006 pilot//Vibration on my steering wheel and gas padal
I own an 2006 pilot with about 78k for several months i'm having problem with vibration on my steering that is more noticeable as the speed increases. my pilot got hit on the front passenger side wheel which threw my alignment out, my wife took the car to sears ( bad mistake), since i wasnt there they change my front struts with cheap Monroe sport tract and wheel alignment. months later i had my tires warrantied because of defects to Michelin tires. the tires was balanced, wheels align, and 60k honda service(transmission,rear diffential fluids changed.) the new tires helped but the vibration still persist. a friend checked my ball joint, CV joint, rods everything is tight. it probably strut or bearings. any suggestion is welcome.
jurena0915 is offline   Reply With Quote
Old 08-26-2011, 08:09 PM   #2 (permalink)
There is a 300 plus post on this issue. I'll look for it when off duty but do a search for shimmy and you'll probably find it
