Stripped screw in key fob - Honda Pilot - Honda Pilot Forums
Old 09-21-2010, 05:06 PM   #1 (permalink)
Default Stripped screw in key fob
The battery in one of our key fobs needed replacing, but when I went to remove the back cover, I found that the screw had corroded. When I tried to remove the screw, I ended up stripping it.
I eventually was able to remove the back cover, but I don't know what to do with it. The bottom half of the screw is still stuck, so I cannot use a new screw (nor do I know where I would be able to find such a small screw).
Since the fob and the key are together, I'm guessing that I'll need to go to the dealer to get a replacement key.
Anyone else have problems with removing the cover on the fob?
1995 Yamaha FZR600
Old 09-21-2010, 05:18 PM   #2 (permalink)
cofetym's Avatar
I usually buy a new Pilot when that happens.
Lens Crafters would probably just give you that
screw.
Don't go to the dealership.Try and come up with
a creative solution for that.
I know you have more than a couple of tools in
your garage.
____________
2005 EX-L 4wd
Old 09-21-2010, 06:02 PM   #3 (permalink)
Those damn bastards put blue LocTite on the screw from the factory, I've broken 2 key shells trying to get that damn screw out.
Old 09-21-2010, 06:22 PM   #4 (permalink)
What did you end up doing... buying new keys? Or is there a way to replace just the shell?
1995 Yamaha FZR600
Old 09-21-2010, 06:27 PM   #5 (permalink)
Yes, had to get new keys off FleaBay.
Old 09-21-2010, 06:27 PM   #6 (permalink)
cofetym's Avatar
Default EBay
Might be time for a retractable key mod.
____________
2005 EX-L 4wd
Old 09-21-2010, 06:30 PM   #7 (permalink)
Tried that, I couldn't get the little transponder out of the OEM key to put it into the new key.
Old 09-21-2010, 07:20 PM   #8 (permalink)
cofetym's Avatar
They really don't want you messing with these keys.
____________
2005 EX-L 4wd
Old 09-22-2010, 11:55 AM   #9 (permalink)
Called my local dealer today. The key costs about $47 and programming it runs about $55. Not too bad considering some of the prices I've heard around here... but still ridiculous considering a new battery would just cost me about $3.
1995 Yamaha FZR600
Old 09-22-2010, 03:21 PM   #10 (permalink)
Maybe take a drill, and drill the smallest hole you can into the stripped screw, so that only the below part of the screw is being used, and the above part is disintegrated. Then just replace the battery, and replace the cover using a temporary flexible glue sealant like Elmers Stix-all cement (it dries clear). That way you can replace the battery again at some point if you need to.
BTW, where can I find the battery for a fob? My CVS or Supermarkets didn't carry that type.
2005 Pilot EX - L. The L is for Love.
akhenax is offline   Reply With Quote
Old 09-22-2010, 05:17 PM   #11 (permalink)
I thought about that too... maybe I'll do that and have a third extra key.
As far as finding the battery, try a place with a decent electronics dept... like Best Buy or Radio Shack. Walmart or Target might even have it. Otherwise, Batteries Plus will have it.
1995 Yamaha FZR600
Old 09-22-2010, 06:03 PM   #12 (permalink)
RadioShack or even PepBoys may have the correct battery for the key. RadioShack will definitely have it, but it'll cost more.
Old 09-22-2010, 06:51 PM   #13 (permalink)
I had this problem, my walmart has the battery...I was able to get the transmitter out carefully without killing the shell. Carefullly pry the opposite end and the shell will come open, slide out the transmitter.
95c1v1c is offline   Reply With Quote
Old 09-23-2010, 09:07 AM   #14 (permalink)
Site Sponsor
hondacuraplanet's Avatar
If you try to drill the screw out, the plastic around the screw will just end up melting. Still though, it accomplishes the same task. Then put a dot of super glue on each corner to hold it back on. If you need to access the battery again, just slice the corners with a razor blade.
www.oemacuraparts.com
Old 09-24-2010, 01:19 PM   #15 (permalink)
Tuck & Jack's Avatar
I just did this last weekend. Use the tip of a very fine drill bit to start a conical depression in the screw, then get a bit set for a electric drill/driver that removes stripped out screws. Use firm but gentle pressure and slow speed to remove it. My set cost about $8 for a set of 3 double ended bits. I used the smallest one to back out the stripped out screw then open the key fob and replace the battery then go to the dealer and get two new screws (one for now and one for the eventual stripping of that one) for $2 each. $12 dollars vs. whatever it costs to get a new key, get it cut and coded. I guess you can decide.
'05 EX-L
'01 Altima SE
'67 Corvette Conv.
Tuck & Jack is offline   Reply With Quote
