Power steering fluid - Honda Pilot - Honda Pilot Forums
Old 08-06-2010, 03:47 PM   #1 (permalink)
Default Power steering fluid
I just put on power steering cooler on my honda. When I drained the reservoir, the fluid was color very dark. Is it normal? Read the manual doesn't say when to replace fluid? Should I? How to?
2008 Pilot SE 2WD Silver
OEM Running Board, OEM Cargo Tray, OEM Moon Roof Visor, Full Size Spare Tire, Husky Liner, After market AT cooler
Happydady is offline   Reply With Quote
Old 08-06-2010, 05:18 PM   #2 (permalink)
Dark is bad.
Fill with new, and re-drain.
How many miles?
Any towing?
Any of the drivers like to hold at lock when parking, backing and such?
Old 08-06-2010, 05:31 PM   #3 (permalink)
IIRC it should be refilled with new fluid every 2 years regardless of mileage.
Old 08-06-2010, 10:25 PM   #4 (permalink)
Good thread on changing it out.
vibration when turning wheel at stand-still - Acura MDX Forum : Acura MDX SUV Forums
Remember to take a peek the screen in the reservoir to make sure it is not plugging up.
I like to just use my oil extractor to suck out the old fluid. Makes for an easy drain and fill. Mine looked like used motor oil at 77k miles. By the 3rd time I did it, the fluid looked very clean again.
http://www.turfeagle.com/products/me...po.OilBoy..jpg
Old 08-06-2010, 11:07 PM   #5 (permalink)
It's 08 with 16k.
Towing 2000 lb trailer twice. Total is about 300 miles for both trips.
You know how the trailer newbie backing it up
Do Honda have ps fluid in big volume? I read from the link above, the needed fluid for drain/fill is 1 quart?
In fact, after replaced one oz of fluid when installed cooler, it makes noise sometime. Now I know because I didn't turn clock to clock enough.
Old 08-07-2010, 12:45 AM   #6 (permalink)
I don't know about the whole system, but the reservoir only holds about 8oz. I just did several drain and fills until it cleaned up. Power steering fluid is cheap.
