Rattle that sounds like my Pilot is made out of plastic? - Honda Pilot - Honda Pilot Forums
 1Likes
  • 1 Post By mclasser
post #1 of 8 (permalink) Old 04-20-2017, 09:49 AM Thread Starter
Guys, I have been chasing a rattle for a long time and cannot figure it out.
This rattle sounds like there is a box full of plastic parts in the back seat. It only occurs when I go over a bunch of medium size bumps. There is a road near my work where there are a bunch of bumps spaced about 2 ft apart and I hit them at about 45mph and can hear the rattle. It sounds like it is coming from somewhere inside the cabin towards the rear, but I cannot be sure, it could be coming from anywhere - very hard to tell.
Here is what I have tried so far:
- removed the rear seats
- removed rear passenger door panel (thought it was coming from there)
- removed the tire jack assembly
- buckled seat belts
- checked exhaust heat shields
- tightened the rear hatch and spare tire
- removed everything from console and door pockets
- fixed rear shock assembly (see my fix here: Rattle from the right rear)
- replaced all sway bar links
Basically, when I go over a bunch of bumps, it sounds like my Pilot is made out of plastic. Does anyone else have this problem?
scottn3 is offline
post #2 of 8 (permalink) Old 04-20-2017, 11:16 AM
can
Check heat shields under the bottom first comes to mind. If you had a passenger in the rear seat, would it do the same thing? A passenger might help to locate the source.
Honda Pilot 2006 LX 4WD J35A9, bought May 2015 with 108,000 Kms / 67,000 miles.
Maintenance so far: New aftermarket rad, New OEM PCV valve, New Costco battery, New intake air duct, "Reman" Denso alternator from Amazon...
Regulate the drones, sign the petition:
can is offline
post #3 of 8 (permalink) Old 04-20-2017, 12:27 PM
mclasser's Avatar
Buckle up all the seat belts. I've had vans and SUVs where the outboard belts hit up against the C & D pillars, causing an annoying racket.
can likes this.
2013 Pilot EX-L 4WD: 40K miles
mclasser is offline
post #4 of 8 (permalink) Old 04-20-2017, 12:31 PM Thread Starter
Thanks for the suggestions, but I've checked those as well. I edited the OP so its in there now.
scottn3 is offline
post #5 of 8 (permalink) Old 04-20-2017, 06:25 PM
Super Moderator
Did you check the secret compartment under the carpeting in the rear cargo area?
humanoid is offline
post #6 of 8 (permalink) Old 04-20-2017, 09:16 PM Thread Starter
Yes, I've removed the rear compartment door completely and all the headrests.
scottn3 is offline
post #7 of 8 (permalink) Old 04-20-2017, 10:55 PM
Bluensleepy's Avatar
Garage
Did you remove the rear side panel? How about tailgate panel?
2014 Honda Pilot Touring 4wd
Disclaimer: I have no idea what I'm talking about.
Bluensleepy is offline
post #8 of 8 (permalink) Old 04-22-2017, 02:39 AM
road2cycle's Avatar
Rear license plate or license plate holder loose?
Brake light, reverse light bulb, or tailgate interior light bulb fell out of the socket?
If EX or EX-L model loose subwoofer?
Rear windshield wiper spring with loss of tension?
Tailgate spoiler loose?
I'm just throwing out some random ideas . . . Hopefully one of them is the cause of the rattles.
2005 Honda Pilot LX
- Aftermarket window tint, Kenwood stereo
2014 Toyota Tacoma Double Cab Longbed 4x4 Limited
- Aftermarket bed lights, In-cab AC power outlet, Auxiliary reverse lights, Door Chime shut-off, Glove box LED lights, Rear differential two-way breather
Previous: 1990 Honda Civic (still running), 2003 Toyota Tacoma XtraCab PreRunner
road2cycle is offline
