power steering belt adjustment tips required. - Honda Pilot - Honda Pilot Forums
post #1 of 8 (permalink) Old 01-03-2017, 09:57 PM Thread Starter
My '04 power steering belt is slipping sometimes, making a noise and jerky steering. I want to adjust it and have the user manual but am having a hell of a time getting at the mounting nut underneath the pump. The engine mount makes access for a socket and ratchet seem impossible. Has anyone adjusted the belt and have any tips they could share. It would be greatly appreciated.
Griffker is offline
post #2 of 8 (permalink) Old 01-03-2017, 11:32 PM
KKL
The serpentine belt runs the steering pump, alternator, AC compressor, etc. It is self-adjusted with a tensioner pulley. Your problem could be due to a tired belt, a bad tensioner, or both. I have an '06 but I believe your '04 is the same - the steering pump is not adjustable.
KKL is offline
post #3 of 8 (permalink) Old 01-04-2017, 11:46 AM Thread Starter
Unfortunately the 04 model has a separate belt for the power steering pump and it is adjusted with a nut provided you can magically undo the other nut underneath the pulley wheel.
Griffker is offline
post #4 of 8 (permalink) Old 01-04-2017, 07:16 PM
xGS
xGS's Avatar
How long has it been (in time and miles) since the belts (including the timing belt) were last replaced?
2003 EX
xGS is offline
post #5 of 8 (permalink) Old 01-04-2017, 07:21 PM
road2cycle's Avatar
If the passenger side motor mount on the 2004 is the same as the 2005 you might be able to do this:
1) Place jack under the oil pan. Use a 2x4 or 2x6. Raise the jack until the wood block contacts the bottom of the oil pan. On my 2005 the engine shouldn't move (based on what I've read) when the passenger side motor mount was removed but I put the jack there just in case.
2) Remove the large bolt which goes between the engine mount bracket (silver) and motor mount (black).
3) Remove the two bolts on the engine mount bracket (silver).
4) At this point you should be able to remove the engine mount bracket.
Hopefully this would give you access to that adjustment bolt you're trying to get to.
Good Luck,
Steve
2005 Honda Pilot LX
- Aftermarket window tint, Kenwood stereo
2014 Toyota Tacoma Double Cab Longbed 4x4 Limited
- Aftermarket bed lights, In-cab AC power outlet, Auxiliary reverse lights, Door Chime shut-off, Glove box LED lights, Rear differential two-way breather
Previous: 1990 Honda Civic (still running), 2003 Toyota Tacoma XtraCab PreRunner
road2cycle is offline
post #6 of 8 (permalink) Old 01-08-2017, 10:08 PM
I've done this several times and never had difficulty. 1/4"-drive socket with an extension is what I use. Since you have slipped this belt, it is done for this world, you need a new belt. When belts slip they glaze and never work properly again, regardless of how tight you crank them (and you don't want to over tighten).
Pilot_Driver is offline
post #7 of 8 (permalink) Old 01-09-2017, 09:14 AM
Originally Posted by Pilot_Driver View Post
I've done this several times and never had difficulty. 1/4"-drive socket with an extension is what I use.......
Unfortunately, this won't work with the power steering belt in the 2004 Pilot. Do what "road2cycle" suggested, but with all that work, replace the belt, instead of adjusting it.
ltp646 is offline
post #8 of 8 (permalink) Old 01-09-2017, 11:06 PM
I have an '04, that's what I do to adjust my PS belt tension, takes 2 minutes.
