I've been reading my brains out and have ended up with information overload. I would like some clear suggestions about some questions i have. I plan on towing an enclosed 6x12 trailer with two dirt bikes in it. shouldn't be more than 3000 lbs with all gear and bikes. The trailer is 1700 empty. I have been towing short distances, but plan on towing a lot more now that the trailer is ready to rock.
1) What is the best way to get an electronic brake controller into my pilot? I would prefer plug and play, but I'm not sure the 2006 has that capability. 2) My pilot didn't come with a towing package, so i am looking to install the necessary coolers. I would prefer OEM, but are aftermarket ones as easy to install and will they keep everything in the optimum operating temp range? 3) After many confusing searches, I have decided to go with the Air Lift 1000 system and will have a shop install it. Please validate my choice in choosing air over a weight distributing hitch. Thanks in advance for taking the time to read/respond. Any questions or comments would be helpful as well. |
#2 (permalink) | |
#2, aftermarket is cheaper and typically better. There are many threads about installations on here for Gen1's. #3, you made a GREAT choice going with the Airlift bags IMO. A WDH is not a great option for those weights and adds some complication you don't need. Now it comes down to proper installation for the bags to work well. |
2012 2WD Touring White Diamond Pearl / Grey 2006 2WD Steel Blue EX-L with Navigation (RIP - 3/10/12) -------------------------------------------------------- My goal in life is to be as good a person as my dog already thinks I am! |
#4 (permalink) | ||
Here is one thread for you to look at.There are plenty more out there and you can read Honda's own instructions on installing the coolers on many of their dealer websites including collegehillshonda etc.
Aftermarket ATF cooler installation with pictures The structural beam you see behind the cooler does have holes pre threaded for the OEM cooler. |
#11 (permalink) | |
Honda says this: "A weight distributing hitch is not recommended for use with your vehicle, as an improperly adjusted weight distributing hitch may reduce handling, stability, and braking performance." If they would have left it at "not recommended" I wouldn't use one. But they don't, so I do. |
#12 (permalink) | |
noted. I will see what the brakes and air bags do for me. WDH is my last resort. |
