#47 (permalink) |
Ah, yes, that's plausible -- although it's gotta be the RDX's engine we compare the Pilot's to, since that is 3.5L -- the MDX has a 3.7L.
-- 2013 Honda Pilot 4WD Touring Obsidian Blue Pearl / Gray Leather |
#49 (permalink) |
Interesting, because I had been under the impression that the Gen 1 MDX did not require premium fuel.
#50 (permalink) | |
I am also fairly sure that there is little to no compression difference between similar size/year Honda and Acura engines.
However beautiful the strategy, you should occasionally look at the results. Sir Winston Churchill Last edited by N_Jay; 01-17-2013 at 09:48 AM. |
#51 (permalink) |
I'm going to slap on twin turbo on mine, tuned for 87octane!!!
2008 Honda Pilot SE, Alpine ATP-445u, Alpine MRV-T420, Polk DB651, Dynamat Max/Peel & Seal, OEM Running Board, Tinted Tails/Glass, LEDs. ![]() RX330 AFS + TSX-R + Curve Shield | Hella Gen 3 55w | Osram CBI 5500k | Putco 2800k H11 Fog |
#53 (permalink) | |
2013 RDX - Powertrain - Honda.com So what does the RDX do differently from the Pilot, since the displacement and compression ration are the same? iVTEC , VCM, Single Overhead Cam on both too. And yet, the RDX claims 273 HP. How do they do it? More air, like Armystrong is investigating, or more aggressive valve timing, or both, or something else entirely?
#54 (permalink) | |
2004 SAGE BRUSH PEARL EXL,REAR SPLASHGUARDS,CARGO LINER,CARGO COVER,CARGO TRAY,CARGO ORG.,OEM WHEEL LOCKS, Delphi XM Radio,Nuvi 350,660 ,Garmin 2620,VIN 522044 |
#55 (permalink) |
Right, so the Acura RDX is the more enticing comparison. Does the RDX's engine just rev faster?
#56 (permalink) | |
We are talking a 10% difference, probably not noticeable by most people.
#58 (permalink) |
I think I may have to kick my own ass for saying this about a Honda Pilot but the most hp per $ for a Pilot would probably be a dry NOS system.
ZEX? EFI - Dry These kits are very easy to install and are universal fit. 75hp for ~$500 Last edited by jamesgarner83; 01-22-2013 at 02:53 PM. |
#59 (permalink) | |
So I just looked it up. The Pilot is spec'ed as 250 HP at 5700 RPM. Red line is 6300 RPM. Meanwhile the RDX is spec'ed as 273 HP at 6200 RPM, red line at 6800 RPM. So, the RDX peaks at 500 RPM faster. That's what I mean. And 10% might be meaningful -- every little bit helps. I for one would prefer 273 HP over 250 HP. Besides, there is still question of how the RDX does it. (I saw an RDX on the road today, and it had a "Turbo" badge on it, but I don't know if all RDX's are turbo or not.) Armystrong was going to look into the intake manifold. Maybe the RDX gets more air. We already know it requires premium fuel so that gives the RDX an opportunity to get aggressive on valve timing. Now we know it revs faster at peak HP.
-- 2013 Honda Pilot 4WD Touring Obsidian Blue Pearl / Gray Leather Last edited by EmptyTank; 01-22-2013 at 03:27 PM. |
#60 (permalink) |
Dunno which year Pilot you have Emptytank, but I have a 2005. For comparison purposes I've always been intrigued by the way the 2005 Acura RL had 300hp, 3.5V6, and AWD.
So clearly some opportunities to improve tune existed back then. It goes to prove that sometimes its worth looking over the Fence |
