Has anyone tried using the "Scangauge II" tool on a VCM engine? Does 3 cylinder operation throw it off?
For example does it calculate MPG as if all 6 cylinders are firing even if they are not?
2007 EX |
#2 (permalink) | |
2004 SAGE BRUSH PEARL EXL,REAR SPLASHGUARDS,CARGO LINER,CARGO COVER,CARGO TRAY,CARGO ORG.,OEM WHEEL LOCKS, Delphi XM Radio,Nuvi 350,660 ,Garmin 2620,VIN 522044 |
Off hand, I would guess the mileage calculation doesn't care which cylinders are or are not firing. I would assume the mileage is calculated simply as a function of how much fuel is used to go a measured distance.
Just a guess. |
I don't think OBD tracks accumulated fuel use. So I'm thinking Scangauge probably gets injector pulse data and counts spark firings, something like that. But the spark plugs actually fire even in the closed cylinder bank VCM mode, for example.
2007 EX |
http://www.hondanews.com/categories/891/releases/4459
2007 EX |
http://www.windmill.co.uk/obdii.pdf The formula: Here are the steps to make the conversion: 1. Divide the MAF by 14.7 to get grams of fuel per second 2. Divide result by 454 to get Lbs fuel per second 3. Divide result by 6.701 Gals fuel per second 4. Multiply result by 3600 to get gallons per hour The expression for GPH is: MAF * 0.0805 To calculate MPG divide the MPH by GPH. The final expression for MPG will be: VSS * 7.718 I think in theory that this would work properly with cylinder deactivation in this scenario. Since the valves are getting shut on the deactivated cylinders, they're not pumping air through the MAF. Interesting about the spark plugs. That makes sense.
2007 EX |
#9 (permalink) | |
