Just drove to CT from little rock and back over the weekend with a short swing to Niagara falls. Used premium and the pilot averaged 19.5-21.5 mpg with high speed highway driving, continuous idling while at the rest stop, etc. tried regular 87 for comparison and it only managed 16-16.5 average mpg. This is on a 2003 honda pilot exlres with X1 thule cargo box, full weight of honda trail package and the just installed sidesteps(thanks tim! arrived on-time before the trip) and with 130,000 miles using mobil 1 5/30 EP. The best mileage was with the sunoco 93 getting 21.5 mpg with average speed of 80+ mph and GW bridge traffic to CT.
#2 (permalink) | |
#3 (permalink) | |
if the price difference is just 20 cents then it was worth it with you getting one gallon free for every fill-up. my range was bumped to 350miles before the low on fuel starts to light up.
Inaccurate measures build better myths than plans. Other than a difference in formulation or a miss-tuned car there is NO technical reason to expect or to get better mileage with higher octane.
2011 Toyota Highlander Hybrid Limited "When you get to the fork in the road, take it." --Yogi Berra |
#9 (permalink) | |||||
quote:
-------------------------------------------------------------------------------- Originally posted by sblvro it was just an observation (light) and not to be disputed as fact. -------------------------------------------------------------------------------- As soon as you start using it to adjust your behaviour, then you have started treating it is fact. it is okay to get 16mpg vs 19-21mpg then? quote: -------------------------------------------------------------------------------- Originally posted by sblvro how would you explain the difference in mileage then? -------------------------------------------------------------------------------- All the ways we have talked about in previous mileage threads. Combined with the ease of miss-assumptions on gas usage caused by poor measurement methods. always your assumption/assertion quote: -------------------------------------------------------------------------------- Originally posted by sblvro how can it be difference in formulation when it says "premium" different brands=same result? -------------------------------------------------------------------------------- Because the formulation is an unknown combined with unreliable measurement methods. which you can always consider as random population hence the different brand but using only premium. short sample size but with x numbers of fill-ups should be reliable. quote: -------------------------------------------------------------------------------- Originally posted by sblvro how can you say it is mistuned when it has been serviced by honda and is in top form than your honda pilot? -------------------------------------------------------------------------------- Because our engines adjust themselves and alternating tanks may add yet another source of error into conclusion. which means it is not mistuned but giving you better mileage with the new fuel=no error in my conclusion quote: -------------------------------------------------------------------------------- Originally posted by sblvro -------------------------------------------------------------------------------- With that I agree!
In most vehicles, the knock sensor is used to adjust the timing. If the fuel is causing pre-detonation, then it retards the timing until that goes away. I don't know if the Pilot fuel management system behaves in the same way, but it's possible that higher octane fuel allows the timing to be advanced a few more degrees resulting in a better mpg.
However, the only experience I have with this in a real world scenerio is higher performance engine that normally require 91 octane.
Current: 2008 4WD EX-L NAV - OEM Tow Package - OEM Running Boards - Sirius conversion using OEM headunit and antenna - Vizualogic A-1250 Dual DVD Headrests - RGB converter for DVD on NAV screen - Hitch-Haul - Air Lift 1000 - USA-Spec PA15-HON2 - DEI 452T Auto Locks Old: 2005 EX-L NAV - Vizualogic headrests - RGB converter for DVD on NAV screen - DMP1 MP3 player - Sirius Starmate Replay - PIE X3 interface - OEM Tow Hitch & Trans Cooler - OEM Running Boards - Hella FF50s - Cross Terrains |
#12 (permalink) | |
#13 (permalink) | |
- Mark |
#14 (permalink) | |
#15 (permalink) |
Hey sblvro
Thanks for sharing your findings. I always wondered if the high cost of Super was worth it. Sounds like it was. Gas has become so expensive I have been driving the speed limit and taking it easy. I have found that this has added another 10-15% extra KM per tank. I may give it a try, if I can stop crying when I see that I just paid $75 to fill it up.
