Precat Deletes for Pilot 05+ - Honda Pilot - Honda Pilot Forums
Old 05-18-2008, 12:53 PM   #1 (permalink)
Send a message via AIM to stillhere153
Default Precat Deletes for Pilot 05+
The title says it all....
here are the pictures
Coming Soon to R-V6P.COM
Precat deletes replace your existing precats with a straight pipes for better flow. constructed of T304 stainless steel. ETA will be around the middle of June.
The precat delete kit will come with everything you need to run without any issues.
2 x OEM Honda Exhaust gasket
2 x Precat to A-Pipe gasket
2 x O2 simulators
6 x Stainless bolt
stillhere153 is offline   Reply With Quote
Old 05-18-2008, 02:29 PM   #2 (permalink)
charly's Avatar
Nice what about the Price...!!!!
How much are we talking here....
"Sogood"
HONDA PILOT LX "07
Old 05-18-2008, 02:52 PM   #3 (permalink)
CMasten's Avatar
empower me.. this means that you replace the crooked, stuffed up exhaust pipes and put these in and I get ? noticeable more horsepower, gas mileage etc?
Old 05-18-2008, 03:03 PM   #4 (permalink)
Sportymonk's Avatar
Based upon the pics which the OP said it all, a fairly stright pipe is replaced with a really striaght pipe. This appears to remove the pre catalytic converter and the O2 sensor.
The emmission and legal implications of this also appear to be obvious. Depending upon how emmissions are measured in your state, you could have issues. Some places don't actually measure the emmissions out of the tailpipe but instead connect to the computer module which calculates the emmssions. If this is the case and the inspector doesn't look at the new pipe and notice the difference, you might be ok. On the other hand, if they measure emmsions at the tailpipe or notice that new piece of metal next to all the old stuff, you could find yourself in violation of the law.
For the money and labor involved, I don't see this being a significant improvement in power.
When I went to Germany in 85 courtesy of the USAF, I was able to buy a pipe from Chrysler of Canada that replaced the catalytic converter since lead free was not widely available back them but it had to go back on when the vehicle re-entered the states.
Old 05-18-2008, 04:39 PM   #5 (permalink)
ctobio's Avatar
Even if your state doesn't measure tailpipe emissions, if deleting the precat causes the OBD system to throw codes, your emissions inspector will see them.
Constantino Tobio
Vehicles in the driveway:
'73 VW Fastback, Marina Blue
'94 John Deere LX176
Old 05-18-2008, 09:24 PM   #6 (permalink)
macphanatic's Avatar
I'd really like someone to run an objective test to see if the catalytic converters really do what they are supposed to. A guy on one of my truck forums ran an emissions test on while on a dyno with them, replace the cats with straight pipes and reran the tests the same way. Same emissions results. He then drove without the cats and got 20% plus economy improvement. Reran the emissions tests and got the same results as the initial tests.
The cats may have been needed years ago before all of the fuel management systems, but is it possible that they don't really do much except drop fuel economy now?
Old 05-18-2008, 10:35 PM   #7 (permalink)
Wonder if this counts as spam.....
Old 05-18-2008, 11:13 PM   #8 (permalink)
ctobio's Avatar
For that dyno test, it's not like the vehicle was driven through the range of conditions it would find- extreme cold, extreme heat, towing, driving in stop and go traffic.
For the operating conditions that the dyno test was run in, perhaps the engine was running under optimal conditions that would produce the least amount of emissions.
Constantino Tobio
Old 05-19-2008, 01:45 AM   #9 (permalink)
the maker of these precat deletes is going to run the price of them under $300... for the kit... later on the line I am not sure
this is not spam whatsoever, i came on here to show you guys what the little cousin (accord v6 ) is working on for the future...
quick answer to some prior questions
these will pass non-visually inspected inspections... the factory heatshields can infact bolt up to these so you can in theory pass visual, but I am not too certain
for states which plug into the obd2 these will pass because the computer will not throw a code... via the o2 simulator both secondary sensors will not read codes... primary sensors are designed for a/f ratio calculations so there is no need for simulators on them
Money and labor... as stated above the precat deletes will cost less than the price of 1 of the factory cats... labor involved is minimal, the engine bay on a honda pilot is roomy... all you need are the proper tools (a rachet) and a set of ramps...
hope I answered questions
lastly should anyone think about the pollutants... there is still a 3rd cat which will in fact operate so you will still pass knox if your state dyno inspects
Old 05-19-2008, 08:12 AM   #10 (permalink)
Dyno test was done in accordance with PA Emissions testing requirements. IIRC, it requires a warm up and is done at specific rpm's. While it may not be perfect, the test raised questions as to the worth of the cats.
Remember that there is only one company that processes the precious metals that goes into these convertors. I wonder if they have a lobbyist?
Old 05-19-2008, 08:23 AM   #11 (permalink)
and I'm sure they eventually handle all the recycled metal from all the cats that get stolen (which has been happening a lot around here lately...cordless sawzall)
'05 Nissan Frontier - 6-spd crew cab, 2" lift, 285/75-16 M/T's (mine)
'06 Accord - 4-dr, 4-cyl auto (hers)(gone)
'08 Pilot AWD (hers)
mainerunr is offline   Reply With Quote
Old 05-19-2008, 08:27 AM   #12 (permalink)
1. His first post is "advertising" these parts
2. His home page is selling these parts
3. His only other post is defending the parts
I think it is SPAM.
On the technical side, what happens to all the hydrocarbons that don't get burned since there is no pre-cat?
I would guess they end up in the cat forcing it to run at higher temps and shortening its life.
Old 05-19-2008, 09:18 AM   #13 (permalink)
I think it is SPAM.
Glad you agree.
Old 05-19-2008, 09:33 AM   #14 (permalink)
And Penguins too!!!!!
Go Steelers's Avatar
I think it is SPAM.
Same person just registered over at www.odyclub.com with the exact same message.
2009 Odyssey EXL-RES - Bali Blue
2008 4WD Pilot EXL-RES - Formal Black
2005 Mazda RX8 GT - Velocity Red
2003 Odyssey EXL-RES - Redrock Pearl <---- Traded
Go Steelers is offline   Reply With Quote
Old 05-19-2008, 09:40 AM   #15 (permalink)
Olde Timer Administrator
colorider's Avatar
I think it is SPAM.
Sounds like SPAM to me as well.
stillhere153, do you even own a Pilot, or did you just come here to market (SPAM) your product? Unless you plan to become a Site Supporter, do not continue to SPAM our site.
Thanks!
'10 Honda Pilot EX-L
'11 Ford Mustang GT/CS
'12 Yamaha XT1200Z
Enjoy Life Today
Yesterday Is Gone
Tomorrow May Never Come
