Mileage Improvement? - Honda Pilot - Honda Pilot Forums
Old 05-12-2008, 07:27 PM   #1 (permalink)
Default Mileage Improvement?
Greetings all -
Aside from the obvious, (tire pressure, driving slower, etc.) has anybody made any changes or modifications to your Pilot to improve gas mileage?
At $4/Gal, every little bit helps!
jparrette is offline   Reply With Quote
Old 05-12-2008, 07:44 PM   #2 (permalink)
Default Re: Mileage Improvement?
Originally posted by jparrette
Greetings all -
You got them all!
Old 05-13-2008, 01:58 AM   #3 (permalink)
rlapid's Avatar
im not sure if this is 'obvious', but replacing the engine air filter regularly helps too.
Old 05-14-2008, 08:53 PM   #4 (permalink)
I am going to put new spark plugs in and am considering the new generation Pulsestar plug.........I already have 105,000 miles on my 2004 and the service interval is coming quickly.......I figure that if I can increase the HP and the MPG by these new plugs then I will........The Denso and NGK NEW Plugs claim big HP and MPG gains as well........
Seth Joseph is offline   Reply With Quote
Old 05-14-2008, 09:41 PM   #5 (permalink)
A6Pilot's Avatar
With all due respect, that is incorrect.
In an computer controlled EFI engine (Honda Pilot, for example) having a dirty air filter will not cut down on your gas mileage. A dirty filter will only lower your mileage if you are driving a car with a carb.
Sounds strange, but here's why:
The computer will continuously adjust the fuel delivered to try for the optimum fuel/air ratio. If your filter is dirty, and thus the air flow partially restricted, the computer will reduce the fuel delivered, maintaining that optimum fuel air ratio. As a matter of fact, by limiting the air delivered at wide open throttle (where economy is at its worst), you may actually improve you mpg! A dirty filter will, however, decrease your peak horsepower, but your mileage will not decrease.
On a car with a carb, the fuel air ratio will get richer (ie. mileage decreases) with a restricted air filter. That's one of the reasons computer controlled EFI systems do not have a choke.
Also, today's engines are equipped with high energy ignition systems. One of the characteristics of HEI systems and associated platinum spark plugs is that engine performance decreases hardly at all as plugs age. The cost of a new set of plugs will not be recovered by the tiny increase in mpg, if you replace them more often than the manufacture's recommendation. That's also the reason installing aftermarket spark plugs is a waste of money. Maybe these Honda powertrain engineers really do know what they are doing.
This is all very counterintuitive, isn't it? It's called a paradigm shift.
Old 05-14-2008, 09:50 PM   #6 (permalink)
I have rouble believing in MPG or Power gains from plugs.
Other than the right heat range (hardly a concern anymore) and indexing, there is no magic in plugs.
Old 05-14-2008, 10:10 PM   #7 (permalink)
A6Pilot's Avatar
With the advent of high swirl heads, spark plug indexing is ineffective. Modern cylinder heads are designed to create tremendous turbulence within the cylinder, thus orientation of the side electrode facing away from the intake valve (indexing) is no longer necessary to produce the highest power.
Installing spark plugs with two or four ground electrodes (some Bosch plugs, for example) may actually increase, slightly, the engines emissions, particularly unburned hydrocarbons.
Things have changed a lot since when I was in high school.
Old 05-15-2008, 01:50 PM   #8 (permalink)
This is too simplistic an analysis.
First, a clogged air filter will increase pumping losses. Engines are big air pumps and it takes considerable effort to pump air in and out an engine and this frictional loss will increase as the air filter clogs.
Second, as I understand it, the Pilot doesn't use a mass airflow sensor (MAF sensor), but instead infers the mass of air coming into the engine based on throttle position, intake manifold pressure, ambient pressure, and intake air temperature. This is a calibrated system and undoubtedly assumes that the pressure loss across the air filter is a value in a normal range. When the air filter clogs, the system will be running out of spec and probably won't be able to compensate, at least not completely. Even engines with true MAF sensors are subject to calibration error when the air filter pressure drop is beyond normal spec.
I agree that the effect of clogged air filter will not be as apparent on a modern FI car as an old carb'ed model. But I don't think you can say that it doesn't matter or that a clogged filter will actually help mileage. This is going WAY too far.
- Mar
Old 05-15-2008, 01:55 PM   #9 (permalink)
charly's Avatar
How about the famous TORNADO anybody has it in their Pilot. And those it helps really.?
"Sogood"
HONDA PILOT LX "07
Old 05-15-2008, 02:59 PM   #10 (permalink)
- Mar
The air filter has to be REALLY clogged to cause these types of problems.
If you are doing anything close to normal maintenance it will not be a problem.
Replacing the air filter early is of no value.
Old 05-15-2008, 07:00 PM   #11 (permalink)
rlapid's Avatar
i don't know anyone who has one on their pilot. as a matter of fact, i don't know anyone who is actually gullible enough to buy one of those. those things are all marketing hype and a scam, imo. if they really did add significant MPG, don't you think the Honda engineers would have added it to all their cars from the factory?
Old 05-15-2008, 08:06 PM   #12 (permalink)
wwong's Avatar
Seth,
If you do get better mileage with the new plugs, let me know.
Custom Non Slip Foam Pads for the Honda Pilot, Click here to visit my website
2003 Honda Pilot EXL-NAV, Starlight Silver, #86733 "Featured Pilot March 2004"
EXTERIOR-Perfect Fit Hood Guard, Lower Trim, Lower Trim Garnish, Bumper Garnish, Fog Lights with Eurodezigns H3 bulbs, Wheel Locks, Fender Flares, Crossbars, Door Mirror Covers, Vent Visors, Running Boards, Rear Splash Guards, Trailer Hitch, Pilot #PM555 Stainless Steel Exhaust Tips, Euro Dezigns H4 replacing Sylvania Silverstars, Tire Minders, EX emblem, Third Brake Light Decal, Michelin CT, Chrome OEM Wheels, Muth Signal Mirrors, Sylvania #885 Back Up Lights
INTERIOR-Wooden Shift Lever, Wood Grain Interior Trim, All Weather Mats, Cargo Cover, Cargo Organizer, Cargo Tray, Cargo Liner, Trunk Organizer, Broadway Optics Mirror, Raybrig R130
ELECTRONICS-Networkcar, Power Inverter, Nav DVD upgrade V.2.11C, Rear View Camera
CUSTOM ACCESSORIES- Door Edge Guard, Foam Pads for Center Console and 2nd Row Activity Tray, Foam Pads for Doors and 3rd Row Bins and Cupholders, Dead Pedal Cover, Cargo Storage Pad, Padded Glove Box, Sunglass Holder Pad, Pillar Protection Tape, Fog Light Covers, Door Reflectors, Cargo Liner Velcro Replacement Kit, Chrome h-p License Plate Frame, VTM-4 emblem, Chrome Accent for the OEM Lower Trim, Chrome Accent for the OEM Running Boards, Chrome Grille Accent, Navi Screen Protector, Non-Slip Pad for the OEM Cargo Tray, hp.org sticker and tee
wwong is offline   Reply With Quote
Old 05-15-2008, 09:07 PM   #13 (permalink)
~snipped
How so? Any sources to this statement?
Old 05-15-2008, 09:14 PM   #14 (permalink)
Simple answer, no. But you can send me the money anyway....
Old 05-16-2008, 07:41 AM   #15 (permalink)
krygny's Avatar
I can top that. Send ME the money and I'll come over to your house and kick you in the nnnyutzz.
2003 EX-L, Sage Brush Pearl
